XC90, 330d, Trophy’s
Having just fitted a set of AST's, I've noticed that the main body that comes through the top mount is a couple of mm larger.
I've drilled out the flat washer part of the upper and lower bushes that they attached through the turret to, but I'm curious about the small collar section that you normally fit between them.
without it there, the upper and lower bush endlessly tighten to the point that they dissfigure themselves, has anyone found any small collars to use as a replacement, or are you running them without the collar atall?
Cheers.
Cheers.
