Rear camber shims
  clio sport 200
Recently bought myself a 182 and the perivous owner had k-tec rear camber shims fitted 1 degree. My question is that will there scrub the inside of the tyres quickly. Having some new 2118's fitted soon and don't want to ruin tyres. Thanks
imprezaworks
  Mk5 Golf GTI :)
Unless your doing big miles no. I've noticed no wear on mine and had them for a while
Sorry to hijack the thread
How does -1 on the rears feel? Im just about to buy 10mm hub spacers for the rear and wondering if I should add some camber? I will be getting the 19mm pure motorsport arb soon aswell so dont know how the 2 will work together, probably fine but wanna check
@imprezaworks
imprezaworks
  Mk5 Golf GTI :)
Get it checked first. Around -1.4 ish as standard. You may need a shim or two to make it level hence checking first.
Unless your doing lots of trackdays I personally would stick with 1.4/5
