Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Noisy engine, Tappets maybe
Discussion in 'Faults, Problems & Solutions' started by Menthis, Jul 9, 2011.
Tags:
  1. Menthis
    Menthis
    May 16, 2011
    2
    Car:
    Renault Clio Grande
    Recently purchased a second hand. Renault Clio grande 1.2 8valve. Its a 2001 model.
    And the engine sounds really crap. Ive been told it could be something to do with the tappets or something. Any help with this would be good thanks.
    Kind of a big newbie with cars etc. so keep technical terms to a minimum if possible.
    Sam
  2. Kirky86
    Kirky86
    Jun 26, 2011
    65
    Car:
    172/A4 Tdi
    Don't know the engines too well myself - did this person mention if they were hydraulic or manual tappets? Check your oil level first - if it's hydraulic and you're running with sod all in the car it'll sound awful.... Other than that, ping a few emails off to garages for a quote on getting them shimmed (If manual) or replaced.
  3. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    When mine did this one of the spark plugs was loose
    Sent from my ZTE-BLADE using Tapatalk
  4. MicKPM
    MicKPM ClioSport Trader
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    Yeah, tappet clearances will need setting... easy enough DIY service job or you can pay a local garage to do it for you.
    Mick
  5. Soot1e
    Soot1e
    Jan 15, 2010
    1,468
    Thundersley
    Car:
    Westy.Audi A3
    And an oil change will help. Might as well go the whole hog and give it a major service. I always do with a new car.
  6. MicKPM
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    The cost of a major service on a 1.2 8v DIET unit is going to be under £40 anyway... why not push that boat out indeed
  7. dudes45
    dudes45
    Jul 15, 2011
    276
    Tadley, Hampshire
    Car:
    Clio 1.2 - 41k miles
    Did a service fix this noise? My car sounds the same, my Dad :/ lol.. Says that its the tappets but it sounds terrible anyway. I am going to do a full service with my Dad :smile: lol.. But yeah I just wanted to know if a service would make it sound better and stop it running rough. It does that to. Cheers guys
  8. MicKPM
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    You will need tocheck and set the valve clearances manually... its part of the service schedule on these but MUST be done with the engine cold.
    Mick
  9. Menthis
    Menthis
    May 16, 2011
    2
    Car:
    Renault Clio Grande
    Thanks for all the replies i have changed the oil thinking this may stop the sound. it didnt i will be changing the tappets some time,
    Does anyone know what the tappet settings are for this model? thanks
  10. MicKPM
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    Inlet 0.1mm, Exhaust 0.2mm both @ cold
    Mick
  • Share This Page
