Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Is adhesion promoter the same as plastic primer?
Discussion in 'Exterior & Bodywork' started by willynwilson, Jun 26, 2008.
  1. willynwilson
    willynwilson
    Apr 16, 2008
    497
    Floodsville!
    Car:
    Clive the Clio no. 2
    I am looking to colour code my strips and i went to a bodyshop and they said they would apply an adhesion promoter, is this the same as normal plastic filler primer from halfords?
  2. Final Maxim
    Final Maxim
    Mar 5, 2004
    9,400
    Wednesbury
    Car:
    Punto/Clio GTT
    no
    plastic primer is a primer for plastics
    adhesion promoter will be scan seal which is used on any new parts
  3. willynwilson
    willynwilson
    Apr 16, 2008
    497
    Floodsville!
    Car:
    is it worth using adhesion promotor for the paint to stick to the side strips? or is plastic primer enough?
  4. Final Maxim
    Final Maxim
    Mar 5, 2004
    9,400
    Wednesbury
    Car:
    Punto/Clio GTT
    if youre in a bodyshop then its just something you do automatically.
    plastic primer is fine.
    its probably confusing
    at one of my old places our plastic primer (adhesion promoter) was clear, which doesnt need to be rubbed down, you just spray it on, let it soak in, then spray on your basecoat. halfords "plastic primer" from what ive seen is coloured stuff that needs to be rubbed down.
    at this place im at now, we use scan seal (adhesion promoter too) which is also clear, but you can use it on metals too. its mostly used for new parts.
  5. willynwilson
    willynwilson
    Apr 16, 2008
    497
    Floodsville!
    Car:
    so if i bought the adhesion promotor, then i dont need primer? i can get plastic primer and adhesion promoter for the same price,
    which one is easier and best?
    Why do you have to rub down plastic primer?
  6. Final Maxim
    Final Maxim
    Mar 5, 2004
    9,400
    Wednesbury
    Car:
    Punto/Clio GTT
    you dont have to rub down plastic primer if its stuff out of a normal tin (used in bodyshops), but the stuff in halfords (aerosol) needs to be rubbed down as it aint the clear stuff
    are you smoothing the strips or are they just rub down and paint? are they textured?
    if they am smooth and pretty much ready to paint straight onto, then id just get the scan seal (adhesion promoter). if you are gonna be looking to fill in any texture, then get the plastic primer as the clear stuff has no covering potential, its just for adhesion promotion
  7. willynwilson
    willynwilson
    Apr 16, 2008
    497
    Floodsville!
    Car:
    its the textured side strips,
    ive tried to do it before, but the paint came off when someone hit it with a car door,
    what can i use to make sure its on for good? so the paint wont come off?
  8. Final Maxim
    Final Maxim
    Mar 5, 2004
    9,400
    Wednesbury
    Car:
    Punto/Clio GTT
    prep it well, clean it well, use adhesion promoter and plastic primer?
    but tbh, you shouldnt really need both, just use one or the other
  9. willynwilson
    willynwilson
    Apr 16, 2008
    497
    Floodsville!
    Car:
    also is hycote plastic primer good enough to use? off ebay for 2 quid!
  10. Final Maxim
    Final Maxim
    Mar 5, 2004
    9,400
    Wednesbury
    Car:
    Punto/Clio GTT
    yea its fine
  11. willynwilson
    willynwilson
    Apr 16, 2008
    497
    Floodsville!
    Car:
    any colour primer is good enough? white, grey, red?
    im spraying blue onto it.
  12. Final Maxim
    Final Maxim
    Mar 5, 2004
    9,400
    Wednesbury
    Car:
    Punto/Clio GTT
    white or grey
  13. willynwilson
    willynwilson
    Apr 16, 2008
    497
    Floodsville!
    Car:
  14. Final Maxim
    Final Maxim
    Mar 5, 2004
    9,400
    Wednesbury
    Car:
    Punto/Clio GTT
  15. willynwilson
    willynwilson
    Apr 16, 2008
    497
    Floodsville!
    Car:
    excellent,
    thanks for your super help, you are my favourite person in the whole world! Lol.
  • Share This Page
