Hand brake
  Clio 182
When I put my hand brake on its not holding at all. Checked the cables all fine and it's tight. Could this be the calipers
  Clio 172
take rear wheels off get someone t pull handbrake and see if leaver on caliper moves.
if it dont bit of greese and loosen it..
if it does loosen handbrake cable right off wind pistons on calipers right in
push brakes a few times till stiff then pull handbrake a few times and adjust if needed
should do the trick.
(take fluid cap off first)
