Gearbox oil
  clio 182 sport
just while this is up i need to do mine, so what about a phase 2 182?? what oil should be used thanks :)
  BG FF 182
I rang up Renault today asking the same question & they said that the gearbox oil should never need changing?
  Clio 2, 1.2 16V
Probably because the oil is designed to last, or they don't want to risk the oil change. The oil needs to be an exact match and needs to be filled more precisely to a specific level.
But then again, the car is probably only designed to get to 100k miles, so might be worth changing it when you reach that level.
  Ckio Sport, 9-5 Aero
shuld i buy
Elf Tranself NFP 75w-80
or
Elf Tranself NFJ 75w-80
or
Motul Motylgear 75W - 80
or none of them?...
its for my Clio 172 ph1
