fog wiring
  b/g 182, meg tourer
when the front fogs are removed, i believe the rear fogs do not work. is there any way of making the rear fogs work when fronts are removed?
or have i got it all wrong and they do actually work?
cheers.
  Astra 1.9Cdti SRi
Edit: forgot i dont have the stalks fitted as their in mates house..
But im preety sure they wont, as its not a full circuit.. Its like you remove the Hazard button your indicators wont work as their on a 1circuit removing would cause a break in it..
  b/g 182, meg tourer
cheers, thats what i thought.
is there any way around this as i would like to still be able to use the rear fogs, and i dont like the look of the front fogs.
Da
  Less
It's a separate circuit on the stalk so as far as I know removing the fronts would have no affect on the rears.
If it does, try fitting a stalk from a base - spec Clio that didn't come with front fogs.
