Cv boot??
  Clio 182 black gold
Had the exhaust done on my car today and the mechanic had a quick look round the car for me as I've only had it a week.
He said my passenger cv boot is leaking. Now I'm no mechanic but I own a spanner or 2 and have more than one brain cell
Would I be able to sort this my self on the drive at home? Any special tool required? And would it be best to replace both sides at same time?
Also it's a Clio 182 55 reg any links for a good price cv boot?
Thanks in advance
leedsboy
  Bean 182 + E70 X5
Depends where it's leaking from. Could just be a case that one of the clips has come loose which is an easy fix.
You really need to take the wheel off and have a look at it properly to see whether it's an easy fix like above or whether it needs replacing.
  Clio 182 black gold
Nice one fella! Well doing an oil change tomorrow so I'll have it off have a look and pop up some pictures!
Guessing the clips a common fault then?
leedsboy
  Bean 182 + E70 X5
Yep, especially if someone's been there before you and replaced the clips with cable ties like someone did on mine. I replaced mine with jubilee clips which definitely won't move.
imprezaworks
  Mk5 Golf GTI :)
I ended up replacing the shaft due to the above. If it splits and stays split for long enough it will cause damage
leedsboy
  Bean 182 + E70 X5
Yup, luckily I caught mine early with no funny noises coming from it.
Rystar
  2003 Clio 172
I've just had the same advisory to change mine out, luckily looks like its only starting to split. It seems there three different sizes of outer passenger side boot? Heard about stretch boots too? Anyone know what size is correct? I've heard about stretch boots too but if I have to split the joint and everything I'd rather use a correctly sized one?
  Clio 182 black gold
Well sorted the cv boot out today, it had just slipped off. So gave it a little clean, slipped it back on and bodge it tie wrap sorted it out for now!
