Creaking from coilovers?
  Fiesta ST200
Hi all, I think my coilovers are creaking a little, not too sure though.
It's noticeable over bumps at low speed, especially reversing up the drive.
They are brand new Spax rsx's so I don't think it's an issue with the dampers.
Any ideas? :/
  Audi A5
I've had a weird screeching sort of noise from on the rear coilovers, located the noise to be coming from the gaitor rubbing on the shaft, I put a bit of red grease on the shaft and it stopped it.
  Fiesta ST200
Cheers, bobby.
I'll get underneath it tomorrow with some grease and slap it up ;)
  Audi A5
My Ktr top mounts creak from time to time when turning at low speeds, a spray of lubricant like wd40 on the bearing stops this. If that's what's causing it.
  172 Cup & K20 Ph1
Sorry forgot to respond to this, however my response was going to be exactly what Bobby said... I had awful creaking due to a seized bearing in the top mounts. WD40 solved this for me! Glad you got it sorted
