hi peeps im after a cheap set of coilovers i've been looking at a set of v max coilovers but i havent got that type of money to spend anyone no off any compaines or makes???
cheers it for a mk2 clio
v max are the cheapest and crappest around. if you cannot afford them then you should not be changing the suspension for coilovers at all. If you can afford them then you need to carry on saving.
I would suggest a set of Eibach sportline springs instead.
Correct however, if you can't afford a set of V-maxxs don't bother.
I will point out however that the V-maxx kits are very well made for money; cam based camber adjustment for easy accurate adjustment at home, proper bolt spacing differences (not 'elongated' holes) etc.
