Car wont start
  Clio mk1 rally :P
Hey.
i just finished changing my cambelt and valves
ive done everything to the book.
i tried to start the car but now it just turns over and doesnt fire...
any one got any ideas???
  172
Go back to basics. Make sure you've conected everything, then make sure you've got a spark, air, fuel and compression.
take them out and with the lead still attached ground them onto a clean bit of the body and get someone to crank tyhe car, if working correctly they should spark then.
  Clio mk1 rally :P
didnt have to do that! IT WORKS!!!!!
i forgot that i had an imobaliser....
SO now its running...
there is a strong smell of fuel and exhaust fumes... is this bad?
Nicolasticity
  Clio 172+MG+SAAB++
First time start today for me too...(since last september) however I connected the battery +ve first, pressed the red button, pressed the lock then opened and it started first time. (need a bit of luck after £600 in bits due to an auxialiary belt)
Fuel in exhaust is no wrries unless its so much that it causes an eplosion which you wont get from cranking unless you do it for a while
  172
There is a lot of smells and smoke after a rebuild, its normally just oil and coolant burning off the block/manifold etc.
  Clio mk1 rally :P
awesome!! thanks alot! all i need to do is finish off the breaks and put it back on the road!!!!
i really miss it .. been driving my GFs pink citreon ax around for ages now :(
lol
