camber
  e91 330d/type r mini
i have had my coilovers fit and i will be getting the car tracked up and the camber done,
what im after knowing is what is the best degree to set the camber up for track
the car is rarely used on the road and i want the best set up for track.
is there a standard camber set up for track or is it down to personal preferance as to how much camber you use?
  182cup & 172 racecar
As Hutchie say's anywhere between 2.6 to 3,4,but to find the best set up you need to take tyre temps across the whole tread with diff pressures etc and then adjust accordingly.
