camber bolts and PM top mounts
  PH1 Track Car
just a quick one, can you still use camber bolts if you use the pure motorsport top mount and strut brace package?
  XC90, 330d, Trophy’s
Yes, the strut brace is tied in to the main body of the top mounts, but the actual strut itself that you adjust using the camber bolts is fixed to the centre of the top mount where it uses a spherical bearing, these are more than capable of taking adjustments in angle to suit the minimal movements you will make at the bottom of the strut.
