Arch liner has a 'bubble' of plastic to the front of the car and behind is the bracket. Took my dremmel to mine. Removed the plastic layer 1st then used a metal cutting disc on it to trim the metal back behind the level of the liner. Then painted on some hammerite paint to stop corrosion.
Think it can be bent slightly to achieve the same. Make sure to seal it if the paint is broken/split.
