ball joints and drive shafts....
  renult clio grande
can anyone tell me on a clio on a X plate, if the drive shafts are spring loaded or on a pin as i need to change them both and also if the ball joints have a 10mm or 12mm nut and bolt as i've rung a few auto spares and they don't have a clue.. many thanxs
  Ph1 172
The driveshafts are held in situ by the strut/hub - remove the hub and they will both slide out, although the passenger side does have 3 bolts to hold the boot on
  Mk1 16v brooklands
Sorry captain, i must if forgot to check his profile, as im on my phone and the screen is zoomed in abit so i can see
  renult clio grande
thank you. i rang a car parts place and they didn't have a clue. do u know if the drive shafts are spring loaded or on a pin as that was also a question the car parts place asked me. as i want to fit them this weekend. cheers
  renult clio grande
engine starting, trouble....
i'm havin problems starting my clio. when it stand for 8-10 hrs it starts up first time but over revs on tick over for a few secs then settles down. if i drive to the local shop, get back it and try and start it, it won't turn over unless i give it some gas. anyone know what it could be? could it be the choke? or i am completely off mark. many thanxs
