Amp Advice-volume control
  ValverInBits
I'm looking into a double DIN setup using an android tablet as a head unit.
I need an amp for this, but I'm worried about volume control. My android phone only has 8 volume settings, i don't expect the tablet to have any more.
Can you buy any 2ohm, 2 channel amps, with a remote volume control? Not bothered about power, >50Wpc
  2007 clio dynamique
Im sure you can get a little device that sits between the phono leads from the headunit to the amp which allows the volume to be adjusted remotely , i remember looking at them
  ValverInBits
Thanks for that, found some of those after a search. Probably what I'm after. Also found a possible software solution. There's an android app to increase the volume resolution that could help.
