Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
6800rpm limit?
Discussion in 'Faults, Problems & Solutions' started by Camerooon, Feb 19, 2012.
  1. Camerooon
    Camerooon
    Dec 30, 2011
    21
    Leicester
    Car:
    Clio 172 Cup
    How do?
    I have recently bought myself an 03 172 Cup and noticed for the first time on Friday when it was on the rollers that it has a 6.8k rev limit.
    With this being my third 1*2 Im fully aware that its supposed to rev to 7200 once fully warmed up but it never goes above the 6800 mark.
    The search function tells me that it's the thermostat but I just wanted one final check before I go ahead and get it done.
    Is the stat likely to be the problem? There are no other heating issues i.e overheating/underheating and the car warms up fairly quickly the same as the cabin heater.
    Any help is appreciated.
    Ta.
  2. Tiger260
    Tiger260
    Oct 13, 2010
    270
    I always thought the limiter cut in at 6750.
  3. James105
    James105
    Dec 17, 2006
    1,011
    High Wycombe- Bucks
    Car:
    Arctic Blue FF 182
    I could be wrong and I will try and find the other thread on this, but I think the water temp sensor located under/ behind the airbox can cause this problem as well.
  4. 172Ben
    172Ben
    May 18, 2008
    10,898
    Crewe
    Car:
    DC5
    are you looking at the dial when checking what its revving to?
  5. Camerooon
    Camerooon
    Dec 30, 2011
    21
    Leicester
    Car:
    Clio 172 Cup
    Ok thanks.
    Up until today I hadnt. I thought it was abit strange when the chap at the RR said it was redlining at that and today on the way home from work I had a look and it wasn't even touching 7k.
    Like I say, I've had a 182 cup and a normal 182 and they both go to 7.2k.
    Its not just a 172 thing is it?
    Does anyone know from knowledge or experience what they usually rev to?
  6. Addicted
    Addicted
    Jul 21, 2010
    10,404
    Worcester, West Mids
    Car:
    Golf 7R w/ DSG
    Pretty sure 7.2k is RS Tuner standard, not actual standard?
  7. sbridgey
    sbridgey ClioSport Club Member
    Dec 5, 2010
    5,229
    Nottingham
    Car:
    Extreme Mode/e91 325
    mine goes to 7200 once fully warmed up
  8. Camerooon
    Camerooon
    Dec 30, 2011
    21
    Leicester
    Car:
    Clio 172 Cup
    Not known to me personally but I've always heard/read that the RS Tuner put the redline at 7800.
    Neither of my 182s had been messed with. :confused:
  9. Steven103
    Steven103 ClioSport Club Member
    Mar 5, 2011
    1,846
    South.
    Car:
    182 attempt #2
    Think this needs a bit of clarification, in bold :tongueout: For ALL PHASE 2 (F4R 738 engine)
    * Standard map: 6800 RPM when cold. When warm it's 7250 RPM in 1st, 2nd and 3rd. 7000 RPM in 4th and 5th.
    * Renault Group N map (standard on Renault Group N ECUs): 7400 RPM in all gears.
    * Most/all RS Tuner maps & lots of specialist maps: 7800 RPM
  10. MartinR
    MartinR
    Aug 14, 2010
    8,334
    Car:
    182
    ^^^^Spot on:smiley:
  11. Camerooon
    Camerooon
    Dec 30, 2011
    21
    Leicester
    Car:
    Clio 172 Cup
    Now we've got that settled :tongueout:...is it likely that the issue is down to the thermostat?
  12. The Fatty
    The Fatty
    Jan 3, 2006
    4,576
    Devon
    Car:
    AB182, Audi A5 3.0
    How can you check if yo have a Group N ECU?
  13. MartinR
    MartinR
    Aug 14, 2010
    8,334
    Car:
    182
    Or incorrect timing
  14. Chip-mk1
    Chip-mk1
    Nov 17, 2011
    23,259
    Notts / London
    Car:
    182/RS2/ Turbo/Mk1
    Yes, if its allowing water to flow through it too soon then the car doesnt get properly upto temperature.
    Trouble is the gauge sits in the middle position for quite a wide range of temperatures, so it will look like its warm enough when its not really.
    So at this time of year, it can take ages of driving the car hard before they go onto the hot limiter.
  15. Camerooon
    Camerooon
    Dec 30, 2011
    21
    Leicester
    Car:
    Clio 172 Cup
    Roger that! Thanks for the help.
  16. bmh.01
    bmh.01
    May 10, 2005
    11,941
    Nuneaton
    Car:
    BMW M135i
    Probably the CTS rather than the thermostat. Where does the temp gauge settle when its warm?
  17. Goodj
    Goodj
    Feb 21, 2008
    12,480
    Ely
    Car:
    Listerine & Poledo
    using decent fuel?
  18. MarkCup
    MarkCup ClioSport Club Member
    Jul 24, 2003
    13,646
    www.youtube.com/markcup70
    Car:
    Fiesta ST MR230
    Not sure this is 100%.
    Mine revs out to 7,750 rpm (indicated) in all gears...well, as far as 4th gear anyway.
  19. Steven103
    Mar 5, 2011
    1,846
    South.
    Car:
    182 attempt #2
    I got my info from here (not saying you're lying or that I'm right, just saying it apparantly came direct from Renaultsport):
    Which can be found here: http://www.cliosport.net/forum/show...u-email-from-renaultsport&highlight=group+ecu
  20. MarkCup
    Jul 24, 2003
    13,646
    Car:
    Fiesta ST MR230
    The ECU I have I understood to be a Renault Group N, but from what you're saying above...maybe it's not. Regardless, it definitely revs out to 7,750...
  21. Cup_Phil
    Cup_Phil
    Jun 15, 2003
    5,355
    Lincoln
    Car:
    E46 M3 SMG
    ^^^ I wouldn't be doing that much without uprating the rod bolts LOL
  22. Chip-mk1
    Chip-mk1
    Nov 17, 2011
    23,259
    Notts / London
    Car:
    182/RS2/ Turbo/Mk1
    Agreed, big risk once you get past 7500rpm IMHO, poorly specced long stroke engines like the F4R mean big strain on the rod bolts.
  23. MarkCup
    Jul 24, 2003
    13,646
    Car:
    Fiesta ST MR230
    Pah. 130k on mine, never missed a beat. I'm sure it'll go eventually, but it's been like this from 2.5k.
  24. Cup_Phil
    Cup_Phil
    Jun 15, 2003
    5,355
    Lincoln
    Car:
    E46 M3 SMG
    I'll stick to 7400rpm on mine. Pointless revving past that as you've gone past peak power anyway!
  25. TomSx
    TomSx ClioSport Club Member
    Nov 10, 2003
    17,341
    Bristol
    Mine was doing this. New CTS and 5 minute change and all was good again.
  26. Chip-mk1
    Chip-mk1
    Nov 17, 2011
    23,259
    Notts / London
    Car:
    182/RS2/ Turbo/Mk1
    Depends on the engine, with an RS2 for example, its still make really strong power at those sort of RPMs, in fact in a lot of cases that is peak power.
    On the restrictive standard inlet though, I agree totally they are packed up and gone home way before then.
  27. MarkCup
    Jul 24, 2003
    13,646
    Car:
    Fiesta ST MR230
    Agreed...it's pretty much useless beyond 6.5k...but it does help save the odd pointless gearchange here and there on track.
  28. Chip-mk1
    Chip-mk1
    Nov 17, 2011
    23,259
    Notts / London
    Car:
    182/RS2/ Turbo/Mk1
    Its not such a problem having a higher limiter if you are only ever there occaisonally, the problem is when you have power up there too so you use the big RPMs a lot, probably why yours has survived so long on a high limiter if its rarely there.
  29. warwickstingray
    warwickstingray
    Aug 3, 2011
    1,217
    Bristol
    Car:
    Pug 206 SW, 172 CUP
    Had this problem. Didn't ***** around and got thermostat and cts changed. Problem gone.
  • Share This Page
