Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
My 182's driver side fog light lens has a crack in it, it seems you cant replace only the glass and it has to be the entire unit, ive got a quote from renault of around £55 which im sure is too much, any suggestions?..
I got the Astrum ones from ecp for my old clio 1.6 (think they are all the same).
it was a bit sh1t really, looked fine from far away and even fairly close once it was fitted, but it felt much cheaper then the oem one but it was 20quid cheaper.
ring round your local scrappy, the same fog lights are used in all the mk2 phase 2 models so one from a 1.2 dynamique would be the same for example. should get it for £10 - £15. hope this helps.
my drivers spot lamp is cracked too ,and they dont work anyway. i got quoted like £50 ish and tht wasnt even from the dealers. cant actually be arsed to do anything about them though as i cant see myself using them anyway
