I think you would need,
standalone engine management system
injectors
Throttle bodies
Steel rod kit
Camshafts
Solid cam follower kit
Valve spring kit
Vernier pulleys
Piston set
Cylinder head mods
Steel crank
It would need to rev to 9000rpm+?
What parts listed are availble for the F4R. Are there any engines running this kind of spec? What would the reliabilty be like?
You could get more power, probably cheaper aswell, from a turbo but an engine that revved to 9000rpm would be fun.
Also a cost estimate for the above. Dependant on management I reckon about £8k not including fitting.
injectors
Throttle bodies
Steel rod kit
Camshafts
Valve spring kit
Vernier pulleys
Piston set
Cylinder head mods
Steel crank
