hello everyone.
Right now I'm thinking about reusing the genuine Brembo calipers.
It all starts with the idea of increasing the brake capacity of TwingoRS.
Luckily I own a Clio200.
I purchased a conversion kit from pure motorsport in order to use the Clio's calipers.
I wanted to increase the brake capacity of the Clio anyway, so I got Megane3's Brembo calipers.
The installation itself was easy, but there was a problem with the compatibility of the disc and pad.
(The inside of the pad is not completely touching the disc.)
Conversion discs were very expensive.
(The Japanese yen is weak against the pound and euro, so it will be a very expensive expense.)
Does anyone know of a reasonable conversion disc?
I found the following products.
I wanted to quickly increase the brake capacity of the Twingo, so I ended up buying a Brembo Clio3 as well.
Therefore, there is no rush.
Clio 3/Megane 2 RS Front 330mm kit with Megane 3 Large calipers - Godspeed
www.godspeedbrakes.co.uk
https://www.kamracing.co.uk/godspeed-caliper-disc-conversion-kit-megane-3rs-renault-clio-mk3-rs.html
