2002 172 - picked up, knock- 1st gear
When stationary, put foot on clutch and into 1st gear to pull away-
about 6 out of 10 times you hear a knock under the car/engine as it slides into 1st gear (happens in no other gears)
think i can feel the sound through the clutch pedal too slightly? If you put it in 1st really really slow...no knock
but its slightly annoying as I havent a clue what it is?
  RenaultSport clio 172 mk2
you have described the same problem as i have got exactly. I would also be interested if anyone has any ideas what this is as my car is booked into the dealer on the 5th for this?
  172 cup'd extreme
bottom dog bone engine mount needs replacing, take a lot of stress and only has rubber bushes. a new one is £31 or you can replace the bushes with powerflex poly items for £30 .
thanks for the info, is this something you have experienced with your car and by replacing the bottom engine mount cure it? Should i mention this to the Renault dealer?
Mine has 6th months main dealer warranty, as bought from renault - guessing they should replace it.
Just a pain in the ass to book it in etc/time of work.
How does the bottom engine mount make the "knock" when going into 1st? Happens with no other gears, only when stationary etc.
is annoying! thanks for the help
Gaz_
  Extreme mode
i thought it was just one of the 172 'quirks' mines always done it, think you'll be hard pushed to find one that doesn't to be honest
  R35 GTR
mine does it too, everyone's does and there are loads of ppl with different solutions. I launched in first and the knocking was so bad that it jumped out of first gear!
great thats exactly what i wanted to hear! all this talk of engine mounts got me worried.
car is on 52 plate, engine mounts going would be worrying!
So just to clear it up
1) Sat at traffic lights
2) Lights go green so put foot on clutch
3) Select 1st gear, as you slide it in you hear a "knock" from the engine/under car area
4) Pull away all ok
(does not happen everytime...but happens alot!)
Gaz_
  Extreme mode
yep, to a tee!, well mins a 52 plate and has just had a replacement steering rack :eek: work that one out, my warrenty runs out on the 30th, thank god they changed it, the part was 300 + vat without labour!
*Update*
Car is at dealers today for the above mentioned problem and they phoned me to say that they think it is something from the clutch area. Problem is that they want me to authorise for the cost of repair because they say that the gearbox needs to be stripped down to see if the problem is the clutch or to see if in fact it is something else which is covered under warranty that is causing the problem! Thing is unless i authorise then they won't strip it down to find out exactly what is the problem so it is kind of a gamble. Do i authorise them to do the work and hope that they find something else which is covered under warranty and then Renault will foot the bill or do i authorise it and end up paying for a new clutch which i don't think is the problem as car is not slipping in the gears and gears are not difficult to select.
Cost of work which includes a new clutch comes to £860 from a dealer.
Has anyone got any advice for me as it would be appreciated.
thanks
If it was the clutch, it should do it in all gears....
Tell them to replace the mounts, if it's not that, atleast you can elimate them from the equation, and they don't cost a fortune.
sometimes if i press clutch down, and just as its knocked into first, you can feel the engine jerk a bit. like the clutch isnt releasing 100%
is my clutch on its way out??
ive also got a knocking when lifting off throttle at like 10mph, which i think is an engine mount - thats going to be fixed on friday at dealer
  RS-1, Bebop, CTR
hm...i get a similar knocking noise when i floor mine in 1th gear...it kicks in at about 4k revs and gets stronger when it reaches the limiter...
the odd thing is, it only does in 1th gear and only when i go full throtle...if i take it up to 7000 gently in doesn't occur...
anything related?
how can i prove that the clutch is fine and not worn out or faulty like the stealership is claiming!?
  C63 AMG, F430 & 172
^^ put it in 5th at 30 n boot it, if it slips then its on its way out,
with knocking when pulling off, they u can just adjust the bottom mount, see the guide at the top of this section, its worked for me!
have finally got my car back from the dealers as did not authorise for the expensive work to be carried out!!
I put it into 5th gear at 30mph and put my foot down hard on the gas and the speed and revs came up together like i would expect it to do. The revs did not shoot up which would indicate a slipping clutch!
Also i can not get the car to make the clunk if i select 2nd gear, only seems to clunk in first like the original problem.
The dealer has said that the clutch is slightly dragging, does this make sense to anyone and does anyone know if this would cause the 1st gear clunk problem??
Has anyone got any other ideas on what the problem could be and would the bottom mount adjusment do anything??
thanks in advance
  The Tube
Mine's a 2002 and clunks every now and then when selecting 1st, I notice it even more after a track day thrashing! It doesn't really bother me though, just character of the car I suppose!
  BMW Z4 3.0i
But why dos it do it? WHY?!!! I ask you goddamnit! No other cars do it. Why is acceptable for a 172 to do it? It happens in my car exactly as described in the first few posts, when engaging 1st in a stationary position.
  Turbo'd MX-5 MK4
mine does it, doesn't bother me though. FFS its hardly the end of the world as we know it.
  Clio 172 mk2
4) Pull away all ok
Sounds familliar..mines more of a clunk sound
TBH @ around 15k I would be really shocked if it's the dogbone bushes....I've come to the conclusion that it's a common trait of the 172/182 and so I just ignore it.
  BMW Z4 3.0i
Cos if you look past your nose and you decide you want to sell it. Take a potential buyer for test drive:
them - "what's that clunk?"
you - "oh that, it's a characteristic, they all do it, it's nothing to worry about :) "
them - "yeah right, I'm off :dapprove: "
  M2 Competition
anything related?
That sounds like your tyres spinning and trying to regain grip mate
  RenaultSport cup172 TT309
Mine does it (bought at 13k) always has. If the gearbox shafts are stationary when selecting first it clunks in. Live with it................
  Clio 172 mk2
Yep....I though it was just a Renault thing as well.
Mine does exactly the same
  M4 LCI, X1, ZX10R
Mine doesn't do it.
I know Chappers849 has had a new gearbox and 2 x clutches and his still does it and his car is the same age as mine.
I would want it fixed if mine did that, as it's got to be doing damaged in the long term?
  clio 172 (2001)
Mine had the exact same noise when selecting first, then on fri evening was in traffic on the m3 on my way to bournemouth i pulled away in 1st lost drive and heard a crunch, was the thrust bearing on the clutch!! Phoning round 2day and renault want £840!!! for a new clutch to supply and fit, cant believe it.
  M4 LCI, X1, ZX10R
Try a RenTech if your down that way instead of Renault.
Most Renault specialist will charge alot less.
I think a garage in Bristol quoted £550 for a new clutch.
  Pikey Truck
If u can drive it properly then it wont do that...
its only if u floor it split seconds before u lift the clutch!!
  clio 172 (2001)
Def didnt floor it, was only in crawling traffic!!!
Thanks dan is there a Ren Tech in the south east?, (car is at home now!!)
  A Real Cup
I get this also...first gear only.
I do wonder like someone who mentioned this earlier it can't be good to hear the engine/gearbox hitting something else!
It so has to be engine mounts and nothing else - mine did this all the time when i had my valver - replaced mounts - end of problem.
Do you drive the car hard? i only ask becasue ordinarily the mounts would last a bit longer than you indicate
