using too much fuel.
Status
Not open for further replies.
  Mazda3 2.2D 185BHP
Hey
so I'm seeing at most 26 MPG no matter how grandmaish I drive.
With a heavy foot it's 22 and below.
The timings are fine as they were checked again by garage, they spot on and I agree considering how the car performs.
Does anyone know what to check next? I don't think there is a fuel leak as I left it for 2 weeks on the drive over a sheet of ply and no marks were found on return at all.
I don't smell fuel when in engine bay when off or after a drive.
Not knowing much about how engines work I don't know what to check next to hopefully fine the cause and then find a solution.
I have read that injectors can dribble causing higher than normal fuel useage, could this be it? How do I check?
I can't afford to send this car back to the garage as I have spent a fortune on it and now need to save for the next time it has to go for repairs lol.
any help and guidance will be greatly appreciated.
Ta
james
  Mazda3 2.2D 185BHP
The computer shows higher MPG such as 35 to 40.
its at the pump I work it out.
My maths is fine ;)
The lambda was replaced last month due to old one not reading correctly.
I was getting about 28mpg with gentle driving, found one of my front brake calipers was binding slightly.
Stripped, cleaned and re-greased all 4 calipers and can now get average 36 just running around rural roads without caning it.
  Mazda3 2.2D 185BHP
How do I check breaks? When car is up I can turn the wheels but they are not as loose as the wife's megane are and have a metal on metal sound.
How many full tanks have you used to calculate it?
4 to 5 mate. The absolute best I managed was 28.5mpg and worst was 19.7 lol.
that's on Momentum 99.
  Mazda3 2.2D 185BHP
No
its 4.5*L per gallon in UK. That's what I use
if you think it's bad you should have seen what it had before I had belts and dephaser done.
Used a whole tank in under 100 miles ;)
  BMW M4; S1000 RR
You would notice that on the trip computer though.
Maybe you've got a fuel thief in the area that happens to have a Clio 2 key (opens all Clio 2 petrol caps).
  Mazda3 2.2D 185BHP
Anyone got any ideas on what I can check? I am tempted to replace the plugs and injectors but not sure if they would help at all.
You mentioned that your brakes might not be right..........metal on metal certainly isn't good.
If they are sticking then that wouldn't help fuel consumption.
Easy to sort out if you know what you're doing, if not get, them checked, even the fast fit places do brakes now
  Mazda3 2.2D 185BHP
I am going to take them apart at end of week and see whats up. Gping to do it myself as cant afford to give money away to garages.
If it was brakes then there wouldn't be a massive discrepancy between the OBC and actual fuel usage.
Understandable. So must be something else.
Would the injectors be at fault? say if one was dribbling ?
  182
Here is an odd one for you. Mine used to show 28max on the computer. 6 months later the box gave up.
Had it rebuilt with the main shaft (s) replaced and all bearings. I refitted it and boom 33 minimum all the time.
Spoke with Martin at agency transmissions who rebuilt it and he said that the worn parts was most likely causing drag so fuel cunsumption was suffering.
Also if your alignment is out it will use more fuel. But as i have said in some of your previous threads its your timing i reckon its wrong regardless of what that garage has said
  Liquid Yellow 182
This is exactly my problem. Im seeing 27.8 normal driving. Just seems like its drinking fuel like its going out of fashion. Ive got a decat and the fuel smell is soo strong too. I think mines running really rich
  Mazda3 2.2D 185BHP
My gearbox does whine so may have a hand in it.
The garage were adamant that the timings are fine, no where close is able to test it apart from them.
There is a Renault garage in Coventrybut they want £95 just to check... No way
  Mazda3 2.2D 185BHP
My exhaust gas smell of fuel...
how do we make it run leaner?
  182
Go to Fred up the road. He will tell you if its right or not and is cheap.
Im not one to use the timing card. But i reckon thats your problem mate.
  Mazda3 2.2D 185BHP
Ok chap.
can you tell me which company Fred works for? I will need to plan a trip to see him. And also to get a price from him
TheEvilGiraffe
South East - Essex
My maths is fine ;).
Something is very wrong here. If you were ~5% different' I'd not be worried. 50% .. something's wrong.
The computer should know how much it's putting in per squirt .. so it should be pretty accurate.
Are you filling and calculating brim to brim ? I assume you are...
How many miles and how many litres are you using on average..........
  Mazda3 2.2D 185BHP
Yup till pump clicks. I use Same pump most of the time.
last tank did 280 miles before needing filling with 48L
I'm typing this whilst lying on the floor, got a bit dizzy for a second
Chrisgti6
  MR2,TT V6,Mini x 2
Odometer fault perhaps? Under reading the miles driven?. Maybe use sat nav to calculate the miles of a journey and see if the odometer is the same.
  Lionel Richie
the acid test - get on the motorway (with the car warmed up) at 65mph and rest trip computer as you're driving, stick at 65mph for 10min and tell me what it reads, it should be around 44mpg, less than 40mpg and its broke (thermostat, CTS, timing, lambda etc)
  Mazda3 2.2D 185BHP
Well.
Drove around a lot today. Car feels different from yesterday.
not sure what srs did lol.
much more snappy.. va va vrooooooom
in regards to fuel still testing.
would it help at all if I was to do the 10 mile @ 65 mph with the rs tuner logging stuff? If so what parameters should I log? :)
  Liquid Yellow 182
I have tryed this, mine started off at about 45 then gradually started going down and sitting under 40mpg. Ive changed lambda, and thermostat. Not done cts or timing. Cts is easy enough, would you be able to have a look at timing for me Fred@BTM
Status
