Lunner said:loosen the handbrake cable?
Lunner said:Do they get hot?
on brake discs. Are you mad man you dont lube up the part that stops your car. Thats like putting some sand in your oil sump. There would be no point having brakes if you lube them. 4D40 = spray, gets everywhere. If you want to lube the moving parts use propper greaseiPap said:Wd40...
so you have no brakes till it burns off then the problem comes backFred2001Dynamic said:WD40 would burn off anyway
iPap said:WD40 isn't a graese, it's a water disperser...
However the comment was a joke.
If someone doesn't know how to adjust their handbreak I would seriously suggest that they don't try because if they aren't competant enough to do that, there is no hope for them!
