£60!!! s**te I guess I wont be replacing that then. Just thought it were best if you know what its like getting them sensors out! Oh ok I dont need the 2nd sensor, so what to plug it into then ?
many thanks eddei have now the easy job of putting it on me car!!! heard its an arse of of a job?
182 have different ECU mapping so if you unplug the secon sensor you'll get the warning light thrown up instantly if you leave it in it will come on in time how long depends could be the next day or 10 years away.is this the same fot the 182 edde, i refitted the second lambda (after cat) when i added my decat last week.
any bebefits/gains from removing it and blanking it up?
mine came on after 3 months, im gunna buy one of those fastchip thingys to reset it at some point. Will it effect the fuelling if you just cable tie the 2nd lambda to something and block the hole?
I just wondered if the fact that i had the second sensor out the way if this would effect the fuelling at all or is the second sensor literally just to check the cat is working
i think you might need to drop the sub frame mate aint 100% tho
