1993 1.4 rt
  1.4 rt Clio 1993
Hi there,
I’m having difficulty starting my 1993 Clio 1.4 Rt. I have a strong spark, so does this rule out immobiliser? When turning on ignition I can hear a relay click,to prime the pump I assume,but there is nothing from the fuel pump. I am getting power down at the plug and I have plugged a new fuel pump in, not in the tank but just to eliminate it, and nothing happens when cranked or upon turning the ignition on. I have bridged 3 and 5 on the relay but still nothing. Any help would be much appreciated. Many thanks
Brigsy
  T.Turbo
If you have power at the pump connector it should be pumping if it works. Id be checking the earth wire for continuity.
