PMS ac delete - fitting with rad in place
haimsey
  ph2 172
As per title really, Is it possible/has anyone fitted the ac delete kit with the rad still in place?
Granted it might be a little more tight/awkward. The cars not really due coolant change as it’s only a couple 1000 miles old
  monaco 172
I fitted a wrc a.c. delete a couple of weeks back and didn't need to remove the radiator, I just removed the air con rad from the front of it.
I can't see why the pms kit would be any different
haimsey
  ph2 172
From memory following their guide they take the rad out. Just as ease of access thing really then I assume
Mertin
  Ph1 172&Ph2 172 Cup
For all the extra time involved I just took the rad out the way to make it alot easier for myself as any space gained is always an advantage when working on the clios!
