Camber bolts
Louis
I Park Like a C**t
Do I need camber bolts? Just recently changed my tres and tie rods so my alignment is out by a fair bit.
The cars lowered on cooksports and running 20mm front spacers/10mm rear.
I don't want to take it for alignment for it to then need camber bolts so I have to pay again.
Louis
I Park Like a C**t
I'd say so mate, as you're guaranteed it will be of from side to side.
I've got a set here if you want them, £10 delivered.
Okay, sounds good.
What make are the camber bolts/condition? And what's the sort of camber i'm wanting to have on the front end?
imprezaworks
  Mk5 Golf GTI :)
Road use upto 1.50. Also depends on the miles you do, assume you don't do lots. As per txt my setup for road use is spot on. I can corner better than most cars on the road and exit speed from roundabouts is breathtaking.
Ish ;)
Louis
I Park Like a C**t
I've ordered some eibach camber bolts, and i'll get it booked in with bramracing next weekend. Will keep the standard wheels on for now then swap over before heading to bram so it's all setup properly. Can't wait!
leedsboy
  Bean 182 + E70 X5
If you get it booked in this weekend, let me know and I'll bob over :)
t90_lle
East of England
Do you need to camber the rear also or just the front? if I got the bolts with 1.5 on the front would 10mm spacer shims with camber on the rear help or hinder the car??
