ClioSport.net Project Cars Time Trial Challenge - January
  Ciio 200
Don't we need photos to prove ?
Sent from my SM-G928F using Tapatalk
  Ciio 200
At the moment that's the fastest time on the board for the 190E. Everything above is RS500 and AMG C-Coupe's.
  Clio182
Best time after 2 hours. Great track, just need to polish the way I approach a couple of corners.
  Goliath I
Next time, can we perhaps choose a car that doesn't handle like the titanic... lol
  Clio182
The handling isn't that bad ! The track is a technical one! Hardly flat is it lol
  Clio182
Right my best time so far with basic car setup. It's on PC with ABS, traction control .
  Goliath I
Gave it a blast earlier, managed around 1.35 mark.
The tracks a bit long for me though tbh.
  Two 0 Shitx
Went a bit faster after a little go again tonight.
1.27.818
Heres the onboard might help show where time is found.
  Listerine & Poledo
I love Cadwell.
But cannot put a lap together, at all.
Apart from when I do my "never change gear" laps. (most of the circuit is 3rd gear, other than 2nd on the forest hairpin)
Seriously, every single bend is a challenge. I am this s**t
I think my registered fastest lap includes several trips to go lawnmowing
JamesBryan
I love Cadwell.
I'm s**t too.
1:36.585 is the best i've done up to now. God knows where some are finding an extra 6-7 seconds on that, as it feels pretty quick!
  Listerine & Poledo
I'm s**t too.
Each corner comes with about a second of extra time to make if you can nail it properly.
The mountain and forest sections are so different too. It's another reason I love the place, you've got to be legitimately good.
Which I, quite clearly, am not.
JamesBryan
Also, i hate the fact that on PS4 i can't use a ghost that is a few seconds quicker than me to see where i can gain time.
Ghost data is only for the top 30-40 overall times which are waaaaay faster :rage:
  Listerine & Poledo
I use my own ghost.
Only trying to better myself, I know all full well I'll never be on the top end of any leaderboard.
JamesBryan
I seem to struggle braking into Park, i either brake too much or not enough and go off onto the grass.
Also through Chris Curve on approach to the Gooseneck.
  Listerine & Poledo
Can't remember if it even lets me do that, i'll have to check.
it sure does,I'm a PS4 person. Cycle through the ghost options.
My Personal Best is the option I use..... .For the 2 valid laps I've managed to complete. (cutting the penultimate corner seems to be my stock party trick)
JamesBryan
Cool.
The tight right hander after Hall Bends? Yeah i've cut that a few times and invalidated the b*****d lap :angry:
  Two 0 Shitx
What platform, wheel or pad, aids, standard tune or custom? Are you in time trail? Did you read the rules?
PS4, pad, had SC on ABS on TC off, standard tune, time trial, the video is done via replay. I think so why?
  Listerine & Poledo
We set rules of doing it all in time trial because that way you've got fixed conditions.
Also you dont get tyre wear or fuel usage so levels the playing field, lap after lap.
It's all good chap
  Two 0 Shitx
Also having TC on especially in the last sector will loose you alot of time even SC looses me nearly half a second in the first two but gains me 2 tenths in the last but im alot more consistant with it on, it's all a trade off.
Best way i find to get faster is forget the ghost, put in a clean lap and then just look at your delta at the top, its live so you can see exactly what you did right or wrong rather than it being just splits or getting distracted by your ghost.
  Listerine & Poledo
If I turn off traction, I end up driving through the rear-view mirror 😂😅😢😢😢😢😢
  Two 0 Shitx
Try turning SC on and TC off if you haven't already. Will understeer a bit more but be more stable.
Euan94
  Volvo C30
Last time we were doing challenges I set the track to rain, set the car to that old lotus F1 thing and said max the boost
everyone bottled it
I remember doing that, it was absolutely hilarious but I think that did for the challenges last time round!
I think I only managed about half a lap at a reasonable pace.
