Upgrade to Espace (2 Pot) Calipers
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
Re: Upgrade to Espace (2 Pot) Calipers -> Wich discs ?
IIRC some members have used the Brembo HC discs from a Scenic 300x24mm.
I can do these for £97 a pair posted. Will be a bit extra for postage to yourself if you are in the Netherlands.
cheers
George
  Clio 172 ph2
Seems like a very cheap way to get big stopping power. Are there any fast road/track pads for this caliper though?
cheers, Matt
  172cup turbo & rx8
Any idea of the model number of the calipers?
  CursedTitanium 182FF
6285-2 is the part number of the drivers side.
  172/1.2/E30
cheers, Matt
Afaik not. But isn't there a company which puts performance compounds on standard pad backplate?
  MX5 NC 2.0 Sport
I plan on picking them up tomorrow, so i can give you guys the part numbers of the calipers :)
These are from a 3.0 v6 espace initiale from 2004
  182
Intresting:D So no need for brackets just a straight bolt on part? ifso i'm off to find some..
  MX5 NC 2.0 Sport
They both have the same mounting points, already measured them today at the scap yard. A direct plug and play upgrade, only thing needed are the 300mm 24mm discs from a scenic.
But this is already been discovered by the user in the link in the 1st post.
Allthough he didn't want to share the exact part numbers ;)
Tunst
  Focus ST225, Focus E
Hmm i may go scower a few scrap yards for these...
sbridgey
  disco 4, 182, Meglio
If you can't get decent pads what's the point? surely standard calipers with decent pads will be better?
  MX5 NC 2.0 Sport
Well for the ones who don't visit the track on a regular basis this is a real interesting (and extremely cheap) upgrade.
Surely some brembo discs/pads with these larger calipers is allot better than the standard stuff ...... :eek:
Found some "possible" decent (not track worthy) pads for these (going to check the sizes tomorrow with the ones that come out of the calipers).
Brembo : P 68 026
Ferrodo : FDB1124
These should be Espace 3.0 V6 mkIII compatible according to the sites.
  172cup turbo & rx8
Pad Dimensions: 155.4 x 71 x 18 (156.4 x 68.5 x 18) for a espace v6 mk3 vs 129 X 55.6 X 18 for a 172
  MX5 NC 2.0 Sport
Looks awesome already, so there are more options than we initially thought ! ;)
  2014 Clio 200t edc
Any pictures? Do these 'look' better/bigger?
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
Confirm pad dimensions when you get chance mate and i'll see what i can get hold of for these. I will be able to get the Brembo oem pads
  MX5 NC 2.0 Sport
Well i got the calipers and made some pictures with the part numbers for you guys.
There a bit bigger for sure, the red is the original ph1 172 (laguna/scenic caliper) the ones on the ph2 172 are a bit different but should have the same mounting holes.
And most important, the proof that it fits without any modification :cool:
Part numbers of the left and right calipers :
  106GTI / NovaC20LET
Nice! Very interested in these. Any idea what discs are needed yet? Will it be a straight forward swap on the discs as well as calipers?
  2014 Clio 200t edc
Looks an ace upgrade. Let us know how they perform. Discs look good too but aren't they 5 stud discs?
would these need a new master cylinder or are they a bolt on work straight away part?
  MX5 NC 2.0 Sport
Well according to the specs it should fit.
Clearly says : "300mm x 24mm 4 stud vented discs"
Regarding the master cylinder, everyone i asked told me it was no problem.
The guy from the 1st post link also said that it would work, so im going to assume its as easy as that ;)
Smokey do the standard 172/182 brake hoses fit? what size wheels are/will you be running?
Willwood 4 pots etc run the standard master cylinder so should be fine tbh
  MX5 NC 2.0 Sport
Just checked the hose and can confirm it fits straight on.
Seems like these cars a ment to be paired with these calipers :D
Im running 16" F1's with spacers so enough space to fit these.
  106GTI / NovaC20LET
Reckon they will fit under 15s? The 280mm discs and standard calipers already quite a tight fit.
  106GTI / NovaC20LET
Might have to stick the turinis back on and give these a go. I find the standard breaks really suffer from fade after about 20/30mins of hard track use. Keep this thread updated on how you get on and if the improvement is worth while.
Good find btw :clap: might of just saved me a fortune. Was gonna update the breaks over the winter, this could be the answer.
  182
Just need pads to be confirmed and whether G172 can get them.
Have now found 2 calipers so shall be having these also.
  MX5 NC 2.0 Sport
Nice ! there are a few on ebay aswell.
Regarding the dics, read on the forum that your not realy a fan of the mtec ones ?
  182
No not a fan mate as they are pretty poor discs tbh and crack between the drilled holes had them on my old valver.
Personally i will be going for the brembo discs off G172..
  MX5 NC 2.0 Sport
Ok, thats makes it official -> Mtec ones off my list.
There are also Zimmerman (German Quality) ones i only have to check what they cost and what the part number is.
  182cup & 172 racecar
Interesting upgrade, shame about not fitting 15's though.
Christopher
  Z4M
Good upgrade for very little money!
Looking forward to see how they perform.
  106GTI / NovaC20LET
isn't it just. Love the way the car handles on lightweight 15s. Gonna give it a try still, sure someone will buy the setup off me if I can't live with the 16s.
  MX5 NC 2.0 Sport
I just ordered the Brembo HC discs. Will share my findings with you guys offcourse, but it can take up to a week till i have time to mount them though :(.
Its definatelly a cheap upgrade i only paid 70 pounds for the 2 calipers :evil:
