Clio TCE Tuning and remapping
  Megane 225
Hi there
Got a clio 1.2 tce Dymanique SX. have already fitted a performace exhaust, a K & N 57i induction kit and a forge motorsport Splittler dump valve. Going to get it re-mapped soo and just wondering if anyone already had if so whats the results ;-). Also if there was anything else i could do to improve performance like change the injectors, where could i get this done?
  182
Sorry i cant help you with upgrades here but...
TBH i think you better off saving for a new car as it is still only a 1.2 engine and the mk3 weighs a small elephant...
  ValverInBits
results are around 125bhp iirc??
As said a bigger front mount will help, but the standard Engine management holds the capabilities back a fair bit.
RSTuning
  R35 GTR
They map well, but injector duty cycle is a concern. Even in stock form they hit 100%!
  Clio 182
Actually it only weighs 1090Kg (as much as an average 1*2) and the 1.2 engine comes with 100ps and can easily go up to almost 130ps with not too much money (advantages of a turbo engine).
Mapping takes it from 100 to 124ps and the exhaust/filter will take it close to 130. Not bad at all.
Nice car for the money mate ;)
  Megane 225
Hi,
Cheers for the replies, got it remapped and it makes it a bit better at overtaking and things like that. The K & N induction kit has been removed as i was getting really annoyed with the constant hissing noise coming from it ;-). Does anyone know where i could go about getting a front mounted intercooler from?
  ValverInBits
Hi,
Have a look at forge FMICs.
also, measure up the area you've got to play with in the bumper and consider buying something off ebay (OEM skyline/Evo Intercoolers.)
  Clio III Turbo 100
Had mine tested and remapped by Midland Remaps at 78,000 miles the car had dropped to 90 Bhp & 100.8 ft-lbs torque,
they got 120.1 bhp + 143 ft-lbs of torque so it is worth it.
Martin_172
I wouldn't want one of these mapped on standard injectors. When paul @ RSTuning done my before map when the car was 100% standard it was hitting 100% injector duty above 4500rpm
even with the 172 injectors fitted and a map it was hitting 85% duty on the 172 injectors im sure!
