JamesBryan
Titanium 182
For the map sensor it's called Intake Manifold Pressure on Torque app.
Going to remove the new decat section this weekend and pull the engine forward. I'm sure it's not sitting right.Voltage wise it looks fine yeah.
I'm not actually sure how fast it should be alternating though, seconds or milliseconds.
Engine. I remember pulling the engine forward a while back and it did improve gear change etc but then soon went back to how it was.The decat isn't sitting right, or the engine isn't?
Not better to pull it forward?Loosen the mounts, let the car idle for a bit and it should find it's own settling point.
Tighten back up.
I'll swap the lambda over as I have one and will be jacking up the car anyway and then can compare. Will have a look at the map sensor reading in a bit!Lambda isn't bad. You don't need to graph the map, just reading with ignition on and then idle.
Line the engine up, don't just pull it one way or the other.
what is it in mbar?
map sensor is bolloxed.
No mapYou got an RStuner map on this?
Just get on with it.
I replaced everything with new at 125k miles in August.
Injectors, coil pack, plugs, HT leads, Lambda`s, air & pollen filter, oil & filter.
Has run faultlessly since, and I am now on 133k, same as you.
Another oil change planned for this week.
Swapped the map sensor, no change.
Got a video of the slight popping at idle, this just normal with a non res decat milltek system?
I'll change the lambda when it's not pissing it down! It's on and off which is really annoying
@JamesBryan did you get chance to have a nosey at your map sensor?
Isn't the manifold pressure the same as atmospheric pressure at ignition? Or is there another way to gauge the overall atmospheric pressure through something else?what reading are you getting for atmospheric pressure and manifold pressure with ignition?
You don`t have a barometer in your hallway?
I feel like you're putting him under pressure here.
Probably find him in the bar.
I'll call me mamYou don`t have a barometer in your hallway?
