Any way to tell if a car has been remapped?
So I've recently picked up another 182, the previous owner seems to think it's had a different inlet manifold fitted in the past and a remap to no doubt go along with that. Is there a way to find out for sure if this is the case? It doesn't have the 5k kick so I'm guessing there is something there that isn't standard. I don't know if it is linked but the revs seem to hang around 1200rpm for a lot longer than you would think normal when you either put the clutch in at higher revs or coast down, it means that stop start and slow moving traffic is a pain in the arse as the car always seems to fight this and so has a tendency to kangaroo slightly rather than just pull from idle. Is this a sign of another problem, vacuum leak perhaps or merely a characteristic of whatever map has possibly been installed? Also the throttle pedal seems very sensitive for the first part of its travel, much more so than I remember it being in my Trophy which was still on the oem map, is this something which is normally altered with remaps? Any help much appreciated.
  Clio 172 cup
My guess is it has matched inlets and a enlarged throttle body , the throttle body will be causing you all those problems take it off and put a standard one on
DrR
  VW Golf GTD
Pretty sure the red line on the rev gauge remains in the same place?
However when it hits the rev limiter changes.
DrR
  VW Golf GTD
lol I've never heard anyone refer to the redline as the rev limiter before, most cars I've had will rev past the beginning of the red line on the rev gauge?
Pass on the redline, will try and get an idea when on my commute tomorrow and see where we are. Is it easy to revert back to a standard map? Otherwise I am tempted by an RSTuner setup but if the throttle body is different (how would I tell, again can take a pic tomorrow) then I guess it may still carry over some of the same characteristics would that be correct? Cheers chaps
  Clio 172 cup
Measure the internal diameter of the throttle body by taking the inlet pipe off 64mm enlarged and 60mm standard plus you can usually tell if the body has been machined anyway , everything your describing is what these enlarged throttle body's do to these clios , it won't be your map if it has one
Nice one thanks, will have a nose and see what it is. Would another throttle body just be plug and play I assume it is?
  dan's cast offs.
it hasn't been mapped, they never have but it's always 'previous owner had it mapped' or 'really fast so has been mapped' etc...:wink:
  Listerine & Poledo
The "5k kick" is a myth anyway.
Can't think why a remap would sit the idle that high either, unless it's had a a lightened flywheel and/or more aggressive cams.
loggyboy
There is a kick, but its a fueling kick not a on VVT kick, thats the myth.
My first assumption with those symptoms would be a bad job on the timing after cambelt swap.
