Which seats on Clio 182 OEM sliders?
LOK
  Trek
Hi guys - I am thinking about putting some reclining sports seats into my 182, was thinking about Sparco R100 or OMP Strada. The point is - I would like to keep the OEM sliders, especially on the driver side since you can raise the seat for smaller drivers. Has anyone on here put aftermarket seats onto the original sliders?
Many thanks!
JON FOZ
  EVO 6
You can mount a wide range of seats onto my VBD Recaro adaptors.
These bolt straight to your existing sliders and allow aftermarket seats to be used.
Jon
  Clio V6 PH1
Jon
Hello Jon,
could you give me more information as i would use RECARO CS in my V6
Regards
  Clio V6 PH1
Hello Jon,
thank you for your reply.
I want to install recaro CS and have to decide which type i should buy. I think the following options are available:
Clio3 RS Recaro CS
Megane RS Recaro CS
original Recaro CS with standard fitting without side airbag.
I do not know the differences ! For what type of seat are your VBD Recaro adaptors. How can I change the seat height. Some Photos or Instructions would be helpful.
Ferdinand.Taubner@gmail.com
JON FOZ
  EVO 6
As far as I know the only ones that my VBD Lowered Recaro adaptors fit are the standard CS without airbag
There isn't a way of altering the height.
You can use either my standard height or my lowered version
  Clio V6 PH1
Hello Jon,
i have the possibility to buy an Recaro CS Renault Clio Driver seat new for 850€. But this is with airbag ! Would this fit on your adapters. What ist the difference in height of your 2 Versions.
Regards
JON FOZ
  EVO 6
That seat will NOT fit.
They have all the Renault specific base on them which makes them sit super high.
My adaptors can only be used with the aftermarket Ines.
My lowered adaptors are 30mm lower than my standard.
  Clio V6 PH1
Hello Jon,
thank you for your reply. I have to use original Recaros !!! I think the normal height is as series in the lowest position ? So I have to decide which height to use. The safety belt buckle remains on the original runner ? How much are your adapters inc. P&P to Germany ? Could you send a picture of your adapters ? Did your Adapter also fit other makes e.g. Sparco ?
I would like to apologize for the many questions. But I would like to carry out the conversion without major problems next May.
  Clio V6 PH1
Hello Jon,
the Link for the Pictures does not exist.
"Sorry, the requested page does not exist.
Please check the URL for correct spelling and capitalization"
JON FOZ
  EVO 6
http://smg.photobucket.com/user/jonfoz/media/Recaro Clio subframes/B781BCCC-0122-4E6B-87F5-A71079E40218_zpsfeydqdws.jpg.html]
[/URL]
  Clio V6 PH1
Hello Jon,
with this picture I have no idea how it is mounted or how it looks. I will get 2 Recaro CS and then report back. The quality of the work seems to be very good!
Can I increase the seat height with distances again when it is too low ?
best regards
  Clio V6 PH1
Hello Jon,
i have ordered 2 new Sportster CS with no airbag so I am in need of lowered Recaro Adapters for my V6. Please send me Pictures and other useful info to my gmail account Ferdinand.Taubner@gmail.com. Then we can also clarify the payment and shipping.
Best Regards
