Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
What oil do renault use?
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by Norris_309, Sep 14, 2006.
Tags:
  1. Norris_309
    Norris_309
    Jul 21, 2002
    1,092
    Bristol
    Car:
    A4 Avant +MK4 Golf
    Does anyone know?
    When you have your 172 serviced at a renault dealer, what oil do they put in?
    If it's half decent stuff do they sell it? as i want to change my oil between service intervals but don't wanna spend a fortune on some, only for it to be changed to cheaper stuff in 6k miles time.
  2. Fletcher
    Fletcher ClioSport Club Member
    Nov 21, 2005
    29,557
    Hampshire
    Car:
    172/FabiaVRS/Hilux.
    Don't they use elf oil?
  3. edde
    edde
    Apr 22, 2003
    29,460
    They use whastever that get a good price and folows Renault guidlines and minimum spec its decinet enough stuff.
  4. oilman
    oilman ClioSport Trader
    Sep 13, 2004
    1,373
    Sunny Cornwall / UK
    As aboved depends who you go to, however they are likely to range from basic semi synth 10w-40 to a fully synth 5w-40.
    Guy.
  5. Norris_309
    Norris_309
    Jul 21, 2002
    1,092
    Bristol
    Car:
    A4 Avant +MK4 Golf
    Back to this question of oil from renault.
    As i think i need to change the oil this weekend.
    I called them today & they said i need Elf 10w 40 @ £25+vat for 5 litres. (that sound ok for a 1yr/6k oil change - in between services)
    When i looked into my clio handbook just now it says:
    For all engines - 5w 40
    For all engines Except 2.0l RS - 10w 40
    whats that about then?
    I take it the Elf 10w 40 for £25 will be fine?
  6. edgerfs
    edgerfs
    Nov 9, 2004
    334
    5w 40 is the optimal oil in the clio sport book, and thats widely documented on this very forum as well.
    Renault dealers of course use 10w 40, because there renault dealers and they treat an rs like a 1.1.
  7. @Spoonie
    @Spoonie
    Jul 4, 2005
    2,950
    I bought my own. £37+VAT for 5 litres of Silkolene Pro S 5w-40w from opie oils. I would tell the dealer you want 5w-40w put in as the handbook states.
  8. Norris_309
    Norris_309
    Jul 21, 2002
    1,092
    Bristol
    Car:
    A4 Avant +MK4 Golf
    It's not due a service, i just thought i'd change the oil after 1 yr / 6000 miles rather than the 2yr / 12000 miles.
    So don't really want to spend £40 on oil if it's going to get changed for £25 10w 40 in another 6k when i take it to renault for it's 24k service. So was just going to use what they use.. otherwise seems a waste.
    (does that make sense??)
  9. edde
    edde
    Apr 22, 2003
    29,460
    have a read here about oil specs
    Renault standards/amaounts of oil/fluid required for the car.
    http://www.cliosport.net/forum/showthread.php?t=166251
    Renault dealers use 5-40 or 10-40 usually and they don't need any special oils. 5-40 is for cars used down to something like -25 degress 10-40 only protects down to -10 (its the in link above the exact numbers) but running on 5-40 is slightly better when cold.
  10. Norris_309
    Norris_309
    Jul 21, 2002
    1,092
    Bristol
    Car:
    A4 Avant +MK4 Golf
    cheers for that edde, starting to make sense now.
    So if i'll try for 5w 40 if not, the 10w 40 will be fine.
    (saying that.. our winters are getting cold! lol)
    Cheers for all your replys
  • Share This Page
