Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
URGENT! How to remove the Wishbone balljoint "pin"
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by Paddy_g46, Mar 28, 2009.
  1. Paddy_g46
    Paddy_g46 ClioSport Club Member
    Nov 1, 2005
    4,332
    My wishbone balljoint went today and my wheel "fell off" and f****ed my wing [​IMG] Iv just gone to remove the balljoint piece to put in the new 1 and iv go the part off the wishbone that is held on with 2 bolts but when i went to remove the piece in the hub (the pin type piece) i cannot get it out! Iv taken bolt and and tried to prise the pin out frm the bottom but just cannot get it out!
    Im thinking that i may have to hammer it out from above? which will invovle removing driveshaft etc! Can anyone tell me what im doing wrong?
    Patrick
  2. sideways danny
    sideways danny
    May 24, 2004
    9,450
    Bedford www.519automotive.co.uk Please Call DON'T
    Car:
    ITB'd MK1
    once it's snapped off you will have to remove the driveshaft and drift it out from above I recon. I've had to use an air-hammer/chisel to remove them in extreme circumstances so if you can't get it out you just need to use more force. A chisel knocked into the split at the back will open up the gap a little to loosen the grip
  3. Paddy_g46
    Nov 1, 2005
    4,332
    ok mate i might have to take the driveshaft out then, how do i go about putting the new 1 back in then? Will it just pop back in?
  4. sideways danny
    sideways danny
    May 24, 2004
    9,450
    Car:
    ITB'd MK1
    the new balljoint should slide in fairly easily once it's lined up. A few blows with a soft faced mallet to tap it in will see you right. you will have to line up the bolt hole with the cut-out to be able to get the bolt back in
  5. Hutchie
    Hutchie
    Jun 19, 2007
    5,777
    Powered by TDF
    Car:
    alien green rs133
    open jaws up with screwdriver/chisel and it will come out..... :confused:^^
  6. Paddy_g46
    Nov 1, 2005
    4,332
    does the pin have to be a certain way around to get it out or what!?
    also does anyone know the driveshaft nut size should i have to remove it?
  7. mini-valver
    mini-valver
    Aug 14, 2006
    8,019
    Stoke
    Car:
    140hp K4M
    30mm IIRC. Might even be 32.
  8. Paddy_g46
    Nov 1, 2005
    4,332
    Ok so when i get this b*****d out, how far in do i need to push the new 1? because as it is the top bit just sticks out fo the new rubber? Do i need to push it up so as that the rubber retracts slightly?
  9. Hutchie
    Hutchie
    Jun 19, 2007
    5,777
    Powered by TDF
    Car:
    alien green rs133
    new one needs to go in until the reduced bit lines up with hole to get bolt through
  10. Paddy_g46
    Nov 1, 2005
    4,332
    ok, so when the recess on the "pin" is the same level as the bolt?
  11. Gs_dang3r
    Gs_dang3r
    Aug 29, 2006
    32
    Bristol
    Car:
    Clio 1.6 16v 2000
    bit of elbow grease is all u need. u could always get a ball joint splitter to do the trick?!
    ive always used a pry bar to force the ball joint seating apart, then hit the bottom arm towards the back of the car until it starts moving, then start swinging from a ma-hoosive levering bar..... but thats all on pugs in a workshop on a ramp with al the tools available.... so possibly a diff situation???
  12. sideways danny
    sideways danny
    May 24, 2004
    9,450
    Car:
    ITB'd MK1
    snapped balljoint so a splitter is about as much use a farting :wink:
  13. Gs_dang3r
    Gs_dang3r
    Aug 29, 2006
    32
    Bristol
    Car:
    Clio 1.6 16v 2000
    ha ha ha, my bad. that needs an extra large tub of elbow grease, an maybe some KY aswell :tongueclosed:
    seein as the ball joint has actually snapped, can u get some oxycetaline on it?
  • Share This Page
