Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Renault trafic van gearbox...
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by bomber, Oct 18, 2011.
Tags:
  1. bomber
    bomber
    Feb 3, 2007
    3,493
    Gloucester B-Spec Skunkworks
    Car:
    Qashcow
    Bit of a long shot here, but we have 6 renault trafic vans of varying age at work. The newest two vans, one of which is mine, are 10 plate and both on about 35k miles. Both under warrenty so at the moment it's not a concern of cost but we need vans to do our job...
    Anyway, randomly now and again they struggle getting into reverse. Once stopped sometimes its nigh on impossible to find reverse. Doesn't matter how much dipping the clutch, revving, it just won't go in. Renault are taking one box out tomorrow to see if anything is amiss.
    Has anyone else got/had the newer age trafic and had/heard any problems with reverse? Obviously I know the problems with the rest of the box and swiss cheese resemblance. An Internet search didn't come up with much
  2. Renault Wolverhampton
    May 18, 2011
    5,937
    Trade Parts Willenhall
  3. bomber
    bomber
    Feb 3, 2007
    3,493
    Car:
    Qashcow
    Couldnt tell you im afraid. 6 speed, facelift vans. The 06 vans we own have been fine with reverse, just rebuilt one of them but that was the other 6 cogs lol
  4. rampantreaper
    rampantreaper
    Sep 2, 2010
    573
    wadebridge, cornwall
    Car:
    172,scenic, trafic
    i have an 07 plate 2.0 dci trafic, evryone will tell you the boxes are crap. mine has never had a thing wrong with it, not the box or anything else. mine just hit 80,000 if thats any help
  5. Renault Wolverhampton
    May 18, 2011
    5,937
    id take a guess at either the gear cables or bearings shafted
  6. bomber
    bomber
    Feb 3, 2007
    3,493
    Car:
    Qashcow
    From what I can remember its done it from new on both vans, mines certainy been from new.
    We've got six of them and had problems with boxes on 4, but they're still cheaper to run inc replacement boxes over a 8 year period than buying the other brands of van etc
  7. rampantreaper
    rampantreaper
    Sep 2, 2010
    573
    Car:
    172,scenic, trafic
    do you get any other problems with them? i have heard of injector probs and som e breaking timing chains? when im fed up with this one i will buy another thats for sure
  8. bomber
    bomber
    Feb 3, 2007
    3,493
    Car:
    Qashcow
    We've had one with the injector problem. The fuel pump breaks down and send aluminium swarf down the line to the engine. As its ally it doesn't get picked up by the magnets and gets through the filter. Ours needed four injectors and was had to come off. That was the same van actually that the box went bang on. 130k on one van and it's been fine since new :smile:
  9. scotty2hotty81
    scotty2hotty81
    May 26, 2006
    2,045
    Birmingham
    Car:
    Clio T 314hp c43 AMG
    Gearboxes
    Turbos
    Injectors
    Premature failing cambelts
    The problem is it's a Renault, I'm pretty sure there are 2 cables one for forward gears and one for reverse it's probably stretched
  10. rampantreaper
    rampantreaper
    Sep 2, 2010
    573
    Car:
    172,scenic, trafic
    mine doesnt have a cambelt!
  11. Daniel
    Daniel ClioSport Moderator
    Jul 21, 2005
    41,576
    THIS IS SHOE
    Car:
    Works GP, Passat Tdi
    I've had three trafic boxes rebuilt in the time i've been trading.
    The third is still at the gearbox place. £800 including vat for removal, rebuild and refit.
    The boxes on them are a pain in the ass. Only weak point on the van though imo. Bloody brilliant vans. Light years ahead of a transit.
  12. rampantreaper
    rampantreaper
    Sep 2, 2010
    573
    Car:
    172,scenic, trafic
    i change the fuel filter on mine alot and always check whats in the filter
  13. christoff_172
    christoff_172
    Oct 31, 2010
    3
    gloucester
    Car:
    clio 172
    With the reverse problem it might be where the selectors exit the box there are bearings that can leak
    Causing the problem so its box out time
  14. lemonnobby
    lemonnobby
    Feb 8, 2004
    5,504
    your all getting mixed up with the trafic models early one are weak espcailly the gearboxs which are pk6
    facelift ones which have the 2.0 dci engine gearboxes are better but they are still stightly week and the code is pf6 iirc
    injectors are a problem due to water ingress but these trafics dont have a lot of problems really
    nick do you work for cf roberts?
  15. bomber
    bomber
    Feb 3, 2007
    3,493
    Car:
    Qashcow
    Lucky for the warrenty, will see what they say next thursday when it goes in :smile:
  • Share This Page
