Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How to change cabin filter?
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by Rhys182, Jan 13, 2007.
  1. Rhys182
    Rhys182
    Oct 7, 2005
    355
    Cardiff, South Wales
    Car:
    RenaultSport clio 172 mk1
    Does anybody have info/procedure for changing the cabin/pollen filter on a 182? Is it a simple 5minute jobby or a bit tricky to get at?
  2. PYE21
    PYE21
    Feb 18, 2004
    1,256
    Lancs
    Car:
    Turbo Beige
    Its not to bad, its located under the slam panel on the drivers side. I think there is three clips to undo and then pull of the plastic panel, you should be able to see where it is once its off. Make sure you put the new one in the right way becasue its a bit of a pain to squeeze in.
  3. Rob669
    Rob669 ClioSport Club Member
    Feb 18, 2005
    1,673
    Southern England
    Car:
    172 Ph1/Scooby MY00
    Relatively simple and more like 15 mins. The slam panel or scuttle panel is below the windscreen on the outside. Just open the bonnet, remove the panel and unbolt the filter housing. Pinch the filter on its sides to get it in and make sure you follow the airflow instructions. Easy.
    Rob669
  4. Rhys182
    Rhys182
    Oct 7, 2005
    355
    Car:
    awesome, thanks guys. give it a crack 2moz if it stays dry enough!
  5. RMDavis
    RMDavis ClioSport Club Member
    Jul 16, 2011
    1,521
    Basingstoke
    Car:
    Impreza Type RA
    Hey guys just a quick question. I've just gone to change my cabin filter on my phase two 172, and it didn't have one fitted lol!? So my query is how does the filter sit? Does it just sit length ways over the inlet? Or pushed into the inlet? A Random question I know but because there wasn't an old one, I don't know how it sits!?
    Cheers Rob.
  6. MRBILLYUK
    MRBILLYUK ClioSport Club Member
    Jun 28, 2005
    8,002
    Lancashire, Wielka Brytania
    Car:
    FF Jeden Osiem Dwa
    It fits length ways . You have to sort of bend / squash it a little bit to get it in , then once it's in it bends back to it's normal shape . Make sure you get it the right way round too , there are arrows on it showing the direction of airflow .
  7. RMDavis
    Jul 16, 2011
    1,521
    Basingstoke
    Car:
    Impreza Type RA
    Cheers mate I better change it lol I thought it was pushed into the inlet. God knows why you'd take it out and no replace the old one!
  • Share This Page
