Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How much toe out @ front?
Discussion in 'Suspension, Brakes, Wheels, & Tyres' started by The Italian, Feb 4, 2009.
  1. The Italian
    The Italian
    Jun 15, 2008
    67
    How much toe out do you run at the fron of your car?
    Stock is 1mm. What do you reckon is best for the track on stock suspension?
  2. BIFCAIDS
    BIFCAIDS ClioSport Club Member
    Feb 17, 2008
    8,004
    Warrington
    Car:
    325d M-Sport & 182
    toe outs for tracks with lots of strights, toe in is for tracks with lots of corners more technical than normal, im just assuming you dont know but what track is it going on you might be after the wrong thing
  3. izibizi
    izibizi
    Mar 22, 2004
    277
    Car:
    172
    you got that wrong, its quite the opposite
    I use 1mm toe out dry, 2mm toe out wet
    its the back end which makes the difference
  4. c__w
    c__w
    Sep 27, 2003
    597
    Generally toe-in adds stability at the expense of some turn-in. Toe-out can make the car feel nervous (although I believe there is a little toe-out as specified at the factory) Setting to parallel is always a good safe bet!!
  5. The Italian
    The Italian
    Jun 15, 2008
    67
    Agreed, toe out @ front = bettern turn in - Toe in @ front = better stability.
    But how do changes of the front toe relative to teh back make a difference?
    Example: more toe at the front vs less toe at the back. Do they both yield teh same results?
  6. izibizi
    izibizi
    Mar 22, 2004
    277
    Car:
    172
    toeing out helps to make the car steer
    generaly 0 toe at back and 0 toe at front is best start for track work
    camber is crucial for tyre wear and handling
    My setup:
    ROAD: 1-2mm toe out with minimum camber, rears standard (toe in, -1,5° camber) predictable, safe setup, good braking and traction
    FAST TRACK: 0 (up to 2mm) toe out and -2,5° camber front and 0 toe, -1,5° camber on the back
    SLOW TRACK: 1mm(up to 3mm) toe out front, 3mm toe out back
    CLIO CUP 172 spec: front 1mm toe out -3,5° camber, back 1mm toe in, 3,3° camber
    CLIO CUP 197 spec: front 2mm toe in -3°10'' camber, back 2mm toe out -2°30'' camber
  7. BIFCAIDS
    Feb 17, 2008
    8,004
    Warrington
    Car:
    325d M-Sport & 182
    yea my bad after reading the post after yours it all come flooding back, (days of GT4 lol)
  • Share This Page
