Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
dealer put wrong oil - will it do any damage?
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by JBarber, May 2, 2008.
Tags:
  1. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    Just had my 24K service. Noticed they've put in 10W40 instead of 5W40 as per the book. I'm going to complain but will it damage my car in the meantime? F*cking useless.
    They're also quoting £125+VAT for PE2 tyres each. Isn't that a bit steep?
  2. Da
    Da
    May 15, 2004
    15,415
    NW
    Car:
    Less
    The oil will not be an issue in the slightest. 10w40 is quite the norm from a dealer! :disappointed:
    As for the tyres, that's about right from Renault but they can be had for less than £100 a corner elsewhere. Do a search it's been coverd hundreds of times mate.
  3. edde
    edde
    Apr 22, 2003
    29,460
    10-40 is the correct spec along with 5-40 etc theres loads of oils you can use.
  4. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    Book says 5W40 for the 2.0 litre engine so I'm going get them to change it. It's written in the front of the service book (shows they don't even read it)
  5. edde
    edde
    Apr 22, 2003
    29,460
    Be careful the dealer can tell you your wrong demanding they chnage it for another oils as the engine is allowed to use the oils only exception is the temps drop below -20 degrees c which ins't going to happen.
  6. -Leigh-
    -Leigh-
    Sep 29, 2003
    4,731
    Wot think? ©
    Yeah, they just use what they have to hand. It won't be a problem.
  7. SkidMarx
    SkidMarx
    Feb 26, 2007
    2,024
    ( . Y . )
    Car:
    172
    Techs dont sit there all day reading people's service book looking to see what the oil grade is. They use the oil thats in the pumps (10w40) as thats all thats supplied. Wont cause any probs, it just aint the best oil to use..
  8. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    The maintenance books says (I quote)
    For the Clio 2.0 16V Renault Sport engine and V6 engine for the Megane II 2.0 T engine, use ACEA A3 5W40 standard oil
    Sh*te english I know but that is exactly what is written
  9. edde
    edde
    Apr 22, 2003
    29,460
    Doesn't make any difference realy. You might be able to tell after say 250k after a life of short cold runs but thats all.
  10. edde
    edde
    Apr 22, 2003
    29,460
    But the manual isn't the rule. The spec is and the spec states you can use it.
  11. SkidMarx
    SkidMarx
    Feb 26, 2007
    2,024
    ( . Y . )
    Car:
    172
    Yea im not sayin you'l notice any diff.. but the oil outta renault pumps is 10w40 semi synthetic...so not the greatest. And a 250k f4r would probly be rattling its tits off anyway, no matter what oil used!
  12. mattjk
    mattjk
    Jun 30, 2007
    3,818
    Bournemouth
    Thats why Im always curious as to why people pay silly money for all this silkolene/motul s**t if you arn't planning on keeping the car for AT LEAST 5years plus then its not going to effect you.
  13. Da
    Da
    May 15, 2004
    15,415
    NW
    Car:
    Less
    A 'manual' is guidance by it's very nature mate. As edde says it's the spec that governs what we can/cannot use.
  14. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    Tosh. It's not in the manual - it's in the service (maintenance) book which is the record the car is properly maintained and hence SPECIFIES the schedule and what work is to be carried out. Anyway, I shall be taking it up with them
  15. Da
    Da
    May 15, 2004
    15,415
    NW
    Car:
    Less
    Good luck :smile:
  16. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    it's going back in for warranty work anyway. I'm sure you're right that in reality in makes no difference, put if you pay a premium to get a Renault stamp in the book the least they can do is carry out the service as per the book
  17. SkidMarx
    SkidMarx
    Feb 26, 2007
    2,024
    ( . Y . )
    Car:
    172
    The majority of renaults serviced at a main dealers are the 1.4's, 1.6's and 1.9.diesels etc, so the oil out the pumps is for those cars.. its only really the turbo diesels that renault insisted u used different oil (5w30 iirc). They wont stock 5 different grades of oil, hence u getting 10w40.
    The best thing to do would be to supply your own oil if its that important, and get some knocked off the service bill.
  18. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    the thing is last time this garage used the right stuff
  19. DrR
    DrR ClioSport Club Member
    Jul 4, 2006
    19,312
    Shropshire
    Car:
    Saab 9-3 Sportwagon
    Your engine will explode long before the type of oil makes any difference.
  20. Da
    Da
    May 15, 2004
    15,415
    NW
    Car:
    Less
    How do you know mate?
    They could put anything in the actual engine, then just invoice it as 5w40 for less hassle :wink:
  21. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    well that's true :smile:
  22. SkidMarx
    SkidMarx
    Feb 26, 2007
    2,024
    ( . Y . )
    Car:
    172
    You should be thankfull theve actually put some oil in it!
  23. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    it's all a f*cking joke. I took it in at 08:15 this morning and from the sheet I can see they started work at 16:17. So £225 for less than an hours work.
  24. mattjk
    mattjk
    Jun 30, 2007
    3,818
    Bournemouth
    umm why dont you service it you self if your so unhappy? Or go somewhere local you know you can trust
  25. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    Me? Get my hands dirty :smile: I'm only interested in thrashing them
  26. ginna
    ginna
    Mar 23, 2007
    640
    Leeds
    Car:
    Clio Sport 182
    it says oxo on buses but they dont sell em !!!
  27. Anonymous
    Anonymous
    Aug 10, 2003
    1,971
    172/Willy/Cayman/66 Splitscreen/MG ZR/Ninja 636
    Car:
    CS Dungeon
    Remind me never to buy a car off of you:wink:
  28. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    insightful
  29. edde
    edde
    Apr 22, 2003
    29,460
    The service book isn't as I'd said the rules. There right within there rights to use that oil.
    They have the service manaul says you ca use it (which you don't have).
    Your point being ? Even seen how much a garage costs to run how muhc people want how efficiently they work how much they cost to train to get the PC's tools ramps taxes pensions company tax etc or how difficult it can be to keep truly accurate start and end times for jobs.
    I guess you aksed for price before you booked it in in which case you should have though before letting them work on your car.
  30. cat171
    cat171 ClioSport Club Member
    Apr 6, 2002
    36,172
    and you've moaned about them using 'the wrong grade' when they haven't as it's still within the grades they can use etc. Riiight :rolleyes:
  31. mattjk
    mattjk
    Jun 30, 2007
    3,818
    Bournemouth
    Lol Mine gets the cheapest 5-40 I can find! about 13 quid a gallon last time I checked! Pukka stuff (well engine doesnt burn any anyway!)
    I change it quite frequently though
  32. JBarber
    JBarber
    Oct 4, 2005
    502
    East Kent
    Car:
    Black/Gold 182
    Humour lost on you guess.
    And my point remains if the book says 5w40, then that's what they should use. If they could use other grades, then the book shouldn't be specific. Anyway, I politely asked the dealer to check and they said they had used the wrong grade and would change it.
  33. cat171
    Apr 6, 2002
    36,172
    Lol, how did he check what grade was in it? How do you know they'll do it?
    They will say leave it here & we'll do it, then probably not bother. Unless you stand over them while they do it, you won't know.
  34. Dash
    Dash
    Oct 18, 2000
    12,565
    Southend
    Car:
    Clio v6
    ^^^ Now that's a point. Even when you supply your own oil, stand and watch them pour it in.
  • Share This Page
