Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Coolant for a Clio 182?
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by Eddie., May 5, 2012.
Tags:
  1. Eddie.
    Eddie. ClioSport Club Member
    Aug 3, 2011
    5,337
    South Manchester
    Car:
    172 Cup
    Right, someone said to me that the 182's use a different coolant to the usual stuff you can buy from Halfords ect..
    Can I just use anything? Or is there a specific type I should use?
  2. CaptainFail
    CaptainFail
    Jun 5, 2010
    253
    Liverpool
    Car:
    BG PH1 Megane 225
  3. rich-6
    rich-6
    Feb 26, 2008
    2,019
    N Yorkshire
    Car:
    Dodgy one
    You want 2 5lt bottles to do it properly
  4. JackJack
    JackJack
    Oct 25, 2010
    5,151
    Devon
    Car:
    JDM EP3
    As said Renault type D.
  5. Eddie.
    Aug 3, 2011
    5,337
    South Manchester
    Car:
    172 Cup
    I'm just changing the thermostat, so I'm not doing a complete change, just will need to top it up. I'll go to Renault tomorrow, if they're open!
  6. Eddie.
    Aug 3, 2011
    5,337
    South Manchester
    Car:
    172 Cup
    Renault are closed tomorrow, deffo Type D that I need? Halfords dont do it do they?
  7. MartinR
    MartinR
    Aug 14, 2010
    8,337
    Car:
    182
    yep definitely type d needed
  8. jesus
    jesus ClioSport Moderator
    Feb 22, 2008
    18,814
    Planning on changing my coolant too, just wondering why this certain type of coolant is needed rather than just any coolant from Halfords or a local shop. Can anyone shed any light?
  9. jamesd1263
    jamesd1263 ClioSport Club Member
    Mar 24, 2008
    1,305
    felixstowe
    Car:
    Mk1 16v brooklands
    Its becuase renault reccomend it, its probably to do with the agents in it that protect water ways and stuff like that, some coolant will eat away at metals
  10. jesus
    Feb 22, 2008
    18,814
    They recommend you run it on 98ron too but 95 is fine. Is it the same sort of thing with this, or are people really against using anything but the proper stuff with coolant?
    Genuine question btw so I know my options :smile: need to get it done over the weekend so may struggle getting the Renault stuff!
  11. rich-6
    rich-6
    Feb 26, 2008
    2,019
    N Yorkshire
    Car:
    Dodgy one
    At £12 its pointless putting anything else in, the red halfords stiff is equivilant to renaults supposedly, i would run that if it was a cheap car,
  12. jesus
    Feb 22, 2008
    18,814
    As said though I really have time to be waiting for the Renault stuff if they don't have it in stock... need to do the coolant flush over the weekend to use the car for Monday, which gives me... today! If needs be though I'll just wait for the Renault stuff. Just wondering what the differences were :smile: cheers.
  13. MicKPM
    MicKPM ClioSport Trader
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    Type-D is a description of the mixture and intended temperature protection range not an actual product name. You need an ethelyn glycol based anti-freeze mixed with water to give protection to -23 degrees. It comes in all different colours do don't be put off by the pretty fluids but never mix brands or colours and never put neat glycol based AF into the system.
    We recommend and use the Renault per-mix for two reasons. Firstly, and the most important, price as its cheap then secondly ease of use. No faffing around with a hydrometer to make sure you've got the correct mix ratio... Just open, pour and you're done.
    Mick
    Diamond Motors
  14. jesus
    Feb 22, 2008
    18,814
    Excellent Mick, thanks for that. I'll hold out until I can get some of the Renault stuff then :smile:
  • Share This Page
