Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Can't select gear - what's up?
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by daddycool, Nov 8, 2010.
  1. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    pulling out of a junction today i changed into second and had no drive. pulled over and i can't select any gears. i got under the car and moved the linkage around on the gearbox end (not the gear stick end) and it feels very loose. is there anything obvious i can check or is it likely something more sinister?
    cheers
  2. henders
    henders
    May 7, 2009
    80
    Near Barnsley
    Car:
    clio 182
    Can you move the gearshift into all positions with the engine running or do you need to have it switched off?
  3. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    i can move the gearstock into all positions with the engine running, doesn't matter if the clutch is depressed or not
  4. franx
    franx
    Oct 2, 2006
    3,218
    Holland
    Car:
    RS Ragnotti
    Check the spring under/on top of the selecter arm on the gearbox
  5. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    i think the spring's ok (it was a bit dark last night) but i'll take another look
  6. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    i can put it into 1st and 2nd with the engine running and clutch out. if i try and put it into 3rd, 4th or 5th it starts to grind with the clutch out. when its in gear the speedo goes up but no drive. it seems like something inside the gearbox isn't selecting a gear. when its in gear, the speedo rises.
  7. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    i'll add that when i'm changing gear (either with the gearstick or directly with the linkage) it's moving like it should and slotting into position. the linkage feels a tad looser than it should but what i can see from under the car looks tight.
  8. franx
    franx
    Oct 2, 2006
    3,218
    Holland
    Car:
    RS Ragnotti
    Get it on a bridge and check the spring under the selectorarm.
  9. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    is that the spring that forces it back into neutral/3rd/4th alignment? right at the end of the linkage just before everything disappears into the gearbox? if so then that seems to be doing it's job, the linkage goes up and down at the spring and resets itself if i knock it out of gear.
    unless i'm missing the point...? :smile:
  10. franx
    franx
    Oct 2, 2006
    3,218
    Holland
    Car:
    RS Ragnotti
    sorry , long time and nobody else answers .. :sleeping:
    Yeah that's the one i meant. Srry , i'm out of ideas
  11. jack_kemp
    jack_kemp
    Jul 28, 2009
    3,133
    Crawley
    Car:
    Stripped yozza'd cup
    Not a clutch problem?
  12. bmh.01
    bmh.01
    May 10, 2005
    11,941
    Nuneaton
    Car:
    BMW M135i
    Not if it grinds into 3rd, 4th and 5th. Do you get drive in the higher gears? Sounds like somethings gone internally in the box tbh. 1st and 2nd share the same selector.
  13. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    no drive in any gears. don't think it's clutch, else i wouldn't be able to just put it into 1st and 2nd with engine running. unless the clutch has welded to the flywheel (???) and it's always engaged.
    it's going into local garage tomorrow. if they have to drop the box out i'll get the clutch done regardless. and some new engine mounts :smile:
  14. bmh.01
    bmh.01
    May 10, 2005
    11,941
    Nuneaton
    Car:
    BMW M135i
    Deffo box internal fault by the sound of it.
  15. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    well, car has been recovered to garage. rac patrol said it was clutch, they mentioned something specific about reverse gear. will report back once garage have called, probably tuesday.
  16. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    i'm sad :worried:
    it needs a new gearbox. chap said the differential has gone. have been quoted £700 for a box from their supplier, £300 + vat to fit, then obviously cost of clutch. ouch.
    so, can i get a cheaper box and what should i be looking for? it's a cup, i think it needs something different to normal, something to do with the speedo?
  17. Andyrg@ ClioTurbo
    Andyrg@ ClioTurbo
    Sep 21, 2004
    4,031
    Clio Turbo Renault Specialists Durham
    Car:
    Trophy Turbo :)
    ull get a box on clio sprt fro #240 mate and 300 to fit there ripping your eyes out!!!! i have a brand new clutch for 45quid posted if you want it i had it as a spare for the track car but went paddle.
    God i charged a lad 100quid to change his box on xmas eve!!!
  18. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    yeah i'll take the clutch, assume it's the same clutch for 172 cup and 172. cheers.
    just seen a box for £250 so i've PM'd the lad.
    i do have my reservations about using a 2nd hand gearbox as what if it goes the same way as the last one, but that's the chance you take to save a couple of hundred i guess. if i get a 2nd hand box, clutch aside, is there anything i should get the garage to replace or check while it's out?
  19. mr bognor
    mr bognor
    Apr 23, 2004
    3,329
    Bognor Regis
    Car:
    Nissan 350Z
    Are you father Christmas ???
  20. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    what could i get for my car as it is without a gearbox? 2002, 75k miles. is £1500 in the realms of possibility or am i looking at more like £1000?
  21. Gray
    Gray
    Sep 25, 2005
    11,025
    Derbyshire
    Car:
    boost
    Depending on the condition on the rest of the car... service history, tyre condition, brakes etc. etc. bodywork etc.
    but not alot with a dead gear box :worried:
  22. Jonny1*2
    Jonny1*2
    Jun 4, 2008
    8,912
    Chorley, Lancashire
    Car:
    Golf GTD Mk7
    Very generous of you mate. A few hours work there. Bet that was fun in the snow :wink:
  23. Jonny1*2
    Jonny1*2
    Jun 4, 2008
    8,912
    Chorley, Lancashire
    Car:
    Golf GTD Mk7
    Oh, and you can put ANY JC5 on the car. You just need to get the UCH reprogrammed to state GB or ABS sensor for the speedo.
    I know a guy who might give you more nearer the 1500mark for it. With a good GB it would be worth around 2.5K ish, so without I doubt it's 1500quid less tbh.
  24. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    I'm interested :smile:
  25. Budgie
    Budgie ClioSport Club Member
    Jan 2, 2007
    10,988
    Fridays on CS are back.
    Car:
    ///M3
  26. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    close, farnborough, hampshire.
    i thought the phase 2 had closer ratios on their gearbox to compensate for the extra weight?
    although i wouldn't be too fussed with longer gearing, as long as the box fitted and worked the speedo
  27. Budgie
    Jan 2, 2007
    10,988
    Car:
    ///M3
    The difference isn't much, and I've had both boxes in the same car.
    You not considered having a crack at it yourself?
    Get the car to mine, and i'll help you swap it for a few pennies!
  28. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    i had thought about doing it myself. i can do most things, just the gearbox/subframe combo freaked me a bit :smile: you make a very tempting offer!
    car is currently in garage awaiting instruction. where abouts are you based?
  29. mr bognor
    mr bognor
    Apr 23, 2004
    3,329
    Bognor Regis
    Car:
    Nissan 350Z
    Was that in the one that i killed :smile:
  30. Budgie
    Jan 2, 2007
    10,988
    Car:
    ///M3
    I'm in Chertsey. Or get it back to yours, and pay me some petrol and we'll do it over a weekend..
  31. Budgie
    Jan 2, 2007
    10,988
    Car:
    ///M3
    LOL. Yeah. Ph1 gearbox went pop, so I fitted a 172 cup one. Hardly any difference, imo.
  32. Gray
    Gray
    Sep 25, 2005
    11,025
    Derbyshire
    Car:
    boost
    it really isnt a bad job to swap the box over...
    in you had a garage with ramps / air tools etc. 4 ~ hrs is achievable
  33. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    very kind of you- that's a great offer of help! i think if it had been before i got it in the garage i would have defo taken you up, but labour at garage to this point is £160, plus recovery back to mine £30, cash for you say £100 plus £20 petrol, that's around £310 fitting and the garage want £310 + vat for the whole labour costs so it makes sense to leave it where it is. if it's ok i'll definitely keep you in mind in future. i'll go for that box in basingstoke. if it fails in a couple of months, check your PM box because i'l need help swapping in another one!!
  34. mr bognor
    mr bognor
    Apr 23, 2004
    3,329
    Bognor Regis
    Car:
    Nissan 350Z
    That was a nice box . much better than normal did you put some special love in it :smile:
  35. jinjur
    jinjur
    Jan 23, 2006
    1,108
    Norn Iron
    Car:
    2003 Clio 172
    Some bloody nice people on here tbh
    J
  36. Budgie
    Jan 2, 2007
    10,988
    Car:
    ///M3
    No problems at all, matey. :smile:
  37. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    i was offered a clutch earlier, do they all use the same clutch?
  38. Gray
    Gray
    Sep 25, 2005
    11,025
    Derbyshire
    Car:
    boost
    yep, but make sure its a full kit, including the release bearing.
    Sent you a PM chap :smile:
  39. daddycool
    daddycool
    Aug 21, 2007
    1,910
    Farnborough
    Car:
    172DD Cup
    cheers, replied :smile:
  40. Tony Hunter
    Tony Hunter ClioSport Club Member
    Jul 23, 2006
    17,931
    Burpspeed HQ Banbury,where else.
    Car:
    182cup & 172 racecar
    We have a completly prof rebuilt box that would fit yours,no miles.Anything that that needed changing was renewed and ready to go £250.
  • Share This Page
