Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Can you put too much grease in CV?
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by H4RRY, Apr 30, 2013.
  1. H4RRY
    H4RRY ClioSport Club Member
    Dec 9, 2011
    292
    Car:
    Clio 182
    Hi,
    after a big winter rebuild, I did my first track day at Anglesey a few weeks ago. I've just come to give the car a once over before Donnington Park next week to find that all three of the cv boots have either got holes in or have blown their clips off. What's makes it worse is they were all new cv boots and clips.
    The only thing that comes to mind is that I put plenty of grease in the cv boots before closing up the boots but now I'm thinking whether I have over done it. Does anyone know if there is indeed a limit t how much grease you should put in a cv boot and if there is, is it because this can happen?
    Any help would be appreciated just so I can see what I did wrong so it doesn't happen again next week :worried:
  2. bmh.01
    bmh.01
    May 10, 2005
    11,941
    Nuneaton
    Car:
    BMW M135i
    Yes you can and for exactly what you describe. Average joint takes 100-120g as a mass generalisation.
  3. H4RRY
    Dec 9, 2011
    292
    Car:
    Clio 182
    Thought that would be the answer, thanks!
    School boy error! :tongueout:
  4. HMS Derv Destroyer
    HMS Derv Destroyer ClioSport Club Member
    Jan 3, 2011
    5,488
    Sir Guy Martin
    Car:
    MK1TD/MGZR/ASTRA'VXD
    yupp correct, as tony would say, too much grease can caulse the boot to fail when the grease gets hot
  5. Tony Hunter
    Tony Hunter ClioSport Club Member
    Jul 23, 2006
    17,930
    Burpspeed HQ Banbury,where else.
    Car:
    182cup & 172 racecar
    Have fun cleaning all that up, a lot of people make the same mistake.
  6. H4RRY
    Dec 9, 2011
    292
    Car:
    Clio 182
    Thanks guys..... And yes, it's EVERYWHERE! :disappointed:
  7. H4RRY
    Dec 9, 2011
    292
    Car:
    Clio 182
    I'm sorry to restart this thread but I have replaced all my cv boots a few weeks ago and after listening to people above I made sure that I didn't put too much grease in the boots and only used the grease supplied in the sachets. Unfortunately at the end of the very next track day I noticed they had all gone again.
    Now i'm totally baffled and a bit annoyed I have to swap them over again :rage:. I just wondered whether anyone knew any other reason why cv boots can explode other than putting too much grease in? I would prefer to work it out now what I'm doing wrong before I swap the boots again this weekend :worried:
    The only thing I'm thinking is whether I wiped enough grease out of the joint before I put the new stuff in but I think I got rid of the worst of it, or are you supposed to totally wash them clean?
    any help that stops me having to buy new cv boots after each track day would be much appreciated :smiley:
  8. sbridgey
    sbridgey ClioSport Club Member
    Dec 5, 2010
    5,229
    Nottingham
    Car:
    Extreme Mode/e91 325
    Remember motor factor parts dont fit. Genuine only.
  9. H4RRY
    Dec 9, 2011
    292
    Car:
    Clio 182
    I've been fitting multi fit to the outer cv's. are they any different to genuine?
  10. MG cup
    MG cup
    Apr 25, 2012
    5,534
    Car:
    Cup In bits
    Your actually bursting the boots everytime or just the clips are coming loose.
  11. Dan519
    Dan519
    Aug 10, 2011
    6,423
    Bedford
    Car:
    DON'T SEND ME PM'S!!
    that only applys to full driveshaft assemblies. A boot is a boot as long as it fits and doesn't split instantly.
    Are you using proper metal clips, or cable ties?
  12. sbridgey
    Dec 5, 2010
    5,229
    Nottingham
    Car:
    Are you sure? I was told the generic one I bought wouldn't fit and I needed to buy a genuine Renault one. Which was over £30.
  13. Dan@SJM
    Dan@SJM
    Oct 15, 2005
    13,230
    Somerset
    Car:
    07969 124504
    The generic ones do work. It's the shafts that don't.
  14. Gray
    Gray
    Sep 25, 2005
    11,025
    Derbyshire
    Car:
    boost
    Dan beat me to it!
  15. Dan519
    Dan519
    Aug 10, 2011
    6,423
    Bedford
    Car:
    ​do you want to think about that one? :tongueout:
  16. sbridgey
    Dec 5, 2010
    5,229
    Nottingham
    Car:
    Well what can I say. You clearly know what you are on about, let's just leave it there.
  17. H4RRY
    Dec 9, 2011
    292
    Car:
    Clio 182
    bursting the boots themselves clips are holding
    metal clips
    The only thing I can think of to totally wash out the cv joint of grease next time and put the sachet in there.
  18. MG cup
    MG cup
    Apr 25, 2012
    5,534
    Car:
    Cup In bits
    No need to wash them out, your either putting the clips far too tight and splitting the boot, fitting the boots to tight together so the ribs are rubbing together or the boots themselves are just the worst chinese rubbish.
    Are you brakes binding too? I have melted cv boots off before when I have had the disks glowing red.
  19. H4RRY
    Dec 9, 2011
    292
    Car:
    Clio 182
    The CV boots are Lucas so they aren't cheap crap.
    I have actually just found that one of my breaks is binding but I don't get the impression that they are melting because of the appearance of the boots however your point about the boots being to tight so the ribs are rubbing could be a great shout!
    I'll see whether I can stretch them along a bit on the driveshaft.
  20. bmh.01
    bmh.01
    May 10, 2005
    11,941
    Nuneaton
    Car:
    BMW M135i
    I've never had much success with the rubber multi fit ones personally. The proper sized plastic ones are much better imo.
  • Share This Page
