Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
2002 1.2 16v Clio Cambelt Change
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by puntoturbo, Jan 2, 2009.
Tags:
  1. puntoturbo
    puntoturbo
    Mar 28, 2006
    9
    s wales
    Car:
    RenaultSport clio 172 mk2
    I'm changing the cambelt, ternsioner and water pump on a mates 2002 Clio 1.2 16v tomorrow due to the water pump leaking,
    Autodata says that a camshaft timing pin needed, is this timing pin needed or does the crank have a keyway where the toothed pulley for the cambelt slides onto the crank. i.e the pulley is not free floating on the crank
  2. SBV116
    SBV116
    Mar 11, 2006
    6,064
    Birchdown.com
    Car:
    Mondeo TDCI 130
    No mate, there is a keyway on the 1.2, its a single cam pulley jobbie. trusty old tipex!!!
    Piece of piss job.
  3. Russ.
    Russ.
    Oct 8, 2005
    3,524
    Stone, Staffordshire
    Car:
    Audi TT 3.2 V6
    My sisters 1.2 Clio is due a cambelt change in March
    Any ideas on rough cost inc alt belt, pulleys and water pump changed?
  4. puntoturbo
    puntoturbo
    Mar 28, 2006
    9
    s wales
    Car:
    sorted then. no problems there! I think a main dealers changed the belt and tensioner about 15k ago. I doubt they changed the water pump though, is it common for the pump to leak on them?
    I picked up a cambelt kit and water pump for £100 Russ 182, you'll probably be looking to pay around £170-190 inc the labour at an independent garage
  5. CountryBumpkin.
    CountryBumpkin.
    Apr 26, 2008
    1,113
    TEG and Sash's Spare room.
    Car:
    UR R26
    mine went, and was leaking like a tap. I was told it was a washer or something.
  6. puntoturbo
    puntoturbo
    Mar 28, 2006
    9
    s wales
    Car:
    Ah right, this ones a strange one. On day it was leaking and using litres of water, then i looked at it and it was dry, topped it up and it was fine for 2 days, now it's leaking again!
  7. Hutchie
    Hutchie
    Jun 19, 2007
    5,777
    Powered by TDF
    Car:
    alien green rs133
    1.2 16v tensioner = 100x more complicated than it needs to be, you need someone to watch pointers underneath :worried:
  8. puntoturbo
    puntoturbo
    Mar 28, 2006
    9
    s wales
    Car:
    any ideas if certain size drill bit can be used as a timing pin for the flywheel or does only the genuine tool made for the job fit?
  9. sideways danny
    sideways danny
    May 24, 2004
    9,450
    Bedford www.519automotive.co.uk Please Call DON'T
    Car:
    ITB'd MK1
    I used a bolt for it the other day (M7 i think). it's not that critical, just makes assembly easier. As already said, the tensioner is the most complicated part of the job, but a mirror makes it doable on your own.
  10. puntoturbo
    puntoturbo
    Mar 28, 2006
    9
    s wales
    Car:
    thanks mate, saves me time messing about. i've got a mirror here that should make things easier with the lining up the pointer.
  11. Alastair.
    Alastair.
    Mar 4, 2006
    7,885
    2017 Megane ST Signiture
    Car:
    Porsche Boxster S
    8mm drill bit straight in the flywheel to lock the crank, tensioners are w**k!
  12. puntoturbo
    puntoturbo
    Mar 28, 2006
    9
    s wales
    Car:
    great stuff, is it ok to undo the main crank bolt against this or should the flywheel be held with a screw driver as autodata instructs!?
  13. sideways danny
    sideways danny
    May 24, 2004
    9,450
    Car:
    ITB'd MK1
    i wouldn't use a drillbit to hold anything with any force, they're brittle
  14. puntoturbo
    puntoturbo
    Mar 28, 2006
    9
    s wales
    Car:
    good point
  15. Alastair.
    Alastair.
    Mar 4, 2006
    7,885
    Car:
    Porsche Boxster S
    ive used my 8mm drill bit for the past 3 years on d4f engines, hasnt broke, dont really put much strain on it anyways
  16. puntoturbo
    puntoturbo
    Mar 28, 2006
    9
    s wales
    Car:
    You've undone the main crank pulley bolt against the drill bit?
  17. shumoboi
    shumoboi
    Oct 13, 2008
    127
    South Wales
    Car:
    BMW 118d
    thats wise
  18. Sean6545
    Sean6545
    Feb 13, 2005
    2,194
    Senior Tech at dealer in South West
    Car:
    Megane dci 130
    Just gun it.
  • Share This Page
