172/182 strut top knocking fix
  Lionel Richie
instead of letting some renault monke..... i mean mechanic loose on your car
you need 2 washers (1 per side) that sit under the suspension top caps
dimensions are as follows
outside overall diameter = 40mm
internal diameter of hole = 18.5mm
thickness = 3mm
where you could buy them from i have no idea, i'm looking into it
I've got some of about that size in the garge I'll try find out where I bought them there a seemingly perfect size.
  Lionel Richie
yeah the ones on the V6 are zinc galvanised steel, but i can't see why ali ones wouldn't work just aswell
well i was just thinking that if i was to get some stainless steel then that would be a bit harder wearing than ali .
  VRS
if anyone gets some made up them let me know and i will take a pair off your hands :) dont mind crossing your palms with a bit of silver for it either :D
  C63 AMG, F430 & 172
i have a box of 100 now
external 37mm
internal hole 18.5
3.5mm thick
2 posted = £1 million dollers
will sell the box to a company to be made into a mass selling product ;) ;)
  RenaultSport clio 182
Is this knocking noise when turning? And can it just suddenly start when its never done it before?
Steve
  ST3 8.5
Where does this washer fit???
As according to the parts info trophy top mounts same as v6???
  C63 AMG, F430 & 172
takes 5mins to fit them.
unscrew the top mount then place washer on the shoulder. re do top mount.
normally renault will grind out the hole where the mount sits. but this seems to be a better fix.
  Lionel Richie
easy to fit, very easy to fit
Steve the top mounts on all mk2 clios are the same, 1.2 16V is the same as a V6 255
only the V6 has the spacer fitted
Steve
  ST3 8.5
I can get 34mm od with 18.5mm internal, 3mm thick in SS for 12p.
Is the od too small????
