Rust spots from cage fitting - fallout remover?
Akay
  Clubman Cooper S
Hi all,
As title, metal particles from cage grinding and welding, have turned to rust spots over the last few months, stuck to the paint. Whats the best way to remove?
Louis
I Park Like a C**t
The rust on the inside? I'd either use an angle grinder and flap disc but this might just cause more problems. Sandpaper, por15, top coat.
leeds_182
North Yorkshire & Humber
Hi all,
Happened to my pals Impreza. I just used about £20 worth of dragons breath!
Akay
  Clubman Cooper S
Its the internal stuff im more concerned about because I cant blast it off with a pressure washer afterward!
JamesBryan
  Titanium 182
Flap disc on a grinder, then put some bilt hamber hydrate80 or kurust on it, then paint.
Coops Mk1
  Lots of Scrap...
I had this on outside of my car when neighbours did something along lines of griding something and fallout all over car
used a claybar and it all came off the paint no worries. obviously turning it very very regularly to avoid scratching
