Steering doesn't return to centre.
  172
As above fellas. I have power steering but when I go around a corner I have no feedback. The wheel does not return to centre. What do you reckon is this a knackered track?
imprezaworks
  Mk5 Golf GTI :)
There is a motor in the column that fails. We had an o4 Clio 1.2 thing in the other week with the exact same problem. Replaced the unit with a good second hand one, cleared codes with a decent scanner (snap on) and jobs a gud un.
What he said^^^ but I'd put her up on a ramp and check the coil springs & CV joints too as Matt suggested
  Many.
172/182's have Hydraulic, not EPAS like the non-sports.
My bet is on top mounts or something bent.
Has it done it the entire time you had the car? or since something? Randomly started?
  PH2 172
You never posted an outcome for this thread.Did it just go away,but left you with the steering wobble that is the subject of latest thread?
Bottom ball joint?
  172
Bottom ball joint?
Ah righty. This is on a different car. This one was for a mate
It needed a new powersteering rack. It had begun to seize inside possibly due to a lack of powersteering fluid.
  PH2 172
Thanks.Please try and conclude a thread with a fix to assist others.
