Car wont go over 4000 revs it just jolts, any help !!!!!
  Renault clio 1.2 16v
i know its does it in 2nd 3rd and 4th and its around 4000 revs, it just jolts and losses power, any help pleaseee!!!!
no mate, and its like a limp too, you know if you floor it when your engine cold and its got no power and it struggles at some point? its same as that but the engiene hot like, :S
itss gonna cost which is annoying, i will get my dad to look at it but i wouldnt of minded finding the problem first :D cheers for the help thoo fletcher :)
i thought the spark plugs earlier, im gonna get the bonnet up and have a look, its only had the spark plugs changed a few months ago, might of gone loose and are jumping out, because it dont always do it, cheers ant :)
well my car was fine untill i noticed it yesterday like it wouldnt go over 4000 revs its like misfiring yeeah, im gonna have a look tomorrow at the spark plugs and see if there fine, how can i check that the ht leads are working fine ?
my mate thinks its an electical problem because it only does it sometimes because it thinks there's a problem then goes on limp mode, but nothing shows me there it is on limp mode, so im gonna check my spark plugs for safety :) cheers for the help ant :)
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
If it was a coil pack it wouldn't suddenly hit a limiter @ 4k rpm. IMHO this is more likely to be a MAP, TB or even a pedal track issue and i'd advise you get it properly diagnosed before shelling out on a replacement coilpack.
Mick
Mick
I told him this, personally to me it sounds like a throttle pedometer issue
it only seems to do it sometimes like, it was fine today when i drove it, but yesterday it wernt bla bla bla, and also i havnt got a engine case and to top it off i went through a massive puddle because of dunelm being set on fire so there was water everywhere, and i noticed it after that, so thats deffoo the cause
