Car turns over but won't start ?
  ITB 428 Ph1
Hi
My 172 sport has sat still for around a month and a week or so, I went to start it and it turns over but will not start. The fuel is at one bar and was put in around 2 months ago. It's had a full service and was no problem up until now ? Any ideas would be appreciated ?
Cheerz Correy
  ITB 428 Ph1
What is the TDC sensor and where is it located please ? I have a very basic understanding so unfortunately it needs to be very simple lol I can not remember about the immobiliser light !
Cheerz Correy
Cheerz Correy
On top of the gearbox underneath the air box.
Looks like
Location
  ITB 428 Ph1
The red dot goes off after a few seconds of turning on the ignition, I just tried to start it and it just will not fire up. I will check the sensor in the morning and let you guys know how I get on. Thanx for your help guys
Cheerz Correy
  ITB 428 Ph1
If it helps, I did run the car for around 15 mins a week ago, after around 2 minutes it died but restarted and ran fine for the next 13 mins untill I turned it off ?
definatly sounds like the tdc, had this problem the day i bought my old one.
i have have one if you are after one.
cheers
chris
  ITB 428 Ph1
No I can't mate, I just tried another 6-8 times to get it started and around the last two times something behind the dash board starting making a noise, like a clicking. I don't dare try no more as my batteries getting flat ?
Cheerz
  PH1 172
Cheerz
That may be the relays you can hear. In the engine bay, try swapping the black tall thin relays around to see if the pump primes.... I will be doing that this evening on mine.
  ITB 428 Ph1
Okay I will give it ago, just cleaned that TDC sensor and it made no difference, what a ball ache it is to get to !
  PH1 172
That will be my next step, heard it's a pain to get to. Also test the clip on the fuel pump end to see if you are getting 12V coz it may be a fuel pump problem.
  ITB 428 Ph1
Evil giraffe did you solve your problem in the end, my cars only covered 42k but spent most of it's time still, I'm going to buy some fuel incase mines gone funny, I think it's more fuel pump related unfortunately ???????
  PH1 172
Yeah he sorted it by changing the 3 relays he mentioned. 1 was the fuel relay and the other 2 got done because they were cheap and look corroded as well.
Let's hope both our cars start after replacing these relays. Order them from RS using the part code as it's only £2.90 each compared with £14 or so it says on here from Renault :S
  ITB 428 Ph1
Okay I've put 5l of fuel in and won't start, I've now been swapping round the 3 relays and i think one may be f**ked , I got what I think was the pump to prime but then my cars flat nOw from all the attempts to start it. I will order the relays as posted and see what happens, what's that yellow square in the fuse box next to the relays ?
Cherz
  PH1 172
Cherz
Not sure what the yellow relay is for mate
TERRY172 have you ordered your relays yet ?
I have not mate because after getting the breakdown guy to have a look we have found the problem. Take a look at my thread mate last post tonight http://www.cliosport.net/forum/showthread.php?596063-Car-will-refuse-to-start hope it helps you out mate
  ITB 428 Ph1
Okay I have removed the plug from the fuel pump and tested the voltage with the ignition on, I only got 300mv DC, therefore I believe my fault to be one of the relays that's not working correctly, hopefully when my new ones arrive, and I've fitted them, my car will kick into life !
  PH1 172
The fact you are getting a low voltage would suggest the relay is not working properly. Hope the new ones sort your problem mate
  PH1 172
Cheerz buddy, will let you know how I get on
Just thought did you swap the relays over and left them swapped over or did you put them back in original places? If you left them in the swapped places then it might not be the relay due to you testing another one.....but we won't rule that out yet.
Try running a 12v feed directly to the pump connection to see if it primes and if it does then try and start the car. If the car starts and then dies when the 12v feed is taken away then you know it's definitely a fuel circuit issue + you know you are getting spark as well
LiamR172
Scotland - NW
i had this problem, it was a rusted earth strap for me, car started perfectly when a new one was fitted
  ITB 428 Ph1
Hi
The car starts woop woop, fitted my new relays that arrived from RS today and it fired up first time. Thankyou all for your help, all the information provided was superb, this has saved me a lot of money and messing about. The knowledge and expertise of the guys on the cliosport forum has cone to my saving grace once again.
Thanks again
Correy
  PH1 172
Glad to hear the car is up and running mate........bet you smiled ear to ear when you heard it fire up haha :)
  clio 172
just to ad incase anyone else has this problem my car died replaced tdc sensor and wasnt tht turned out to be an old fuse had cracked so no fuel from the pump so tadaaaaa there u go hope it helps someone out there
  Clio 172 2002
Yes I did mate, just so happy it was a quick fix !
Great thread! My clio phase 2 has started to be hard to start recently. Pump seems to be priming but it has been a pain especially if the car is parked on a hill with the rear facing downwards.
Before I ordered a new crank position senson I found this thread. Swapped the relays around and it started first go. Hopefully this was it!
