Finally lowered my TCE!!!!
  Slow red one
Finally done it:) only 30mm but am glad no more since I've already heard it bump over speed bumps lol! loving the difference and stance compared to standard since i've nether driven a lowered car.
Big thanks to renault_wizz for fitting!
Before:
After
Comments welcome and shall get better pics soon on my camera as they were on my phone.
  Not a 320d
20/25mm spacers now and itll be good. 30mm isnt much though is it !!!???
Whats it sitting on, prolines ?
  White Sti Hatch
Lol as said your nether happy unless it's scrapping the floor! Personally I love the difference and glad I didn't go lower cause it already scraps on speed bumps as is.
Not much difference either way seems pointless to spend the money for no noticeable difference at all
Yeah I'm thinking of spacers next but dont know much about them, where can you get them from and how much? Easy to fit?
FK System B spacers are the only ones to buy, 25mm is perfecton the mk3
Bolt to the hub the the wheel bolts to the spaces none of this longer bolts pish ! they aint cheap though !!!
  Not a 320d
Good ones arent. Course you could always settle for cheap spacers, just dont turn corners with them on.
  White Sti Hatch
Where from bio?
i got the from Russ@gas almost a year ago hes not trading ne more far as i know so it would be direct from FK but like i said they aint cheap i wouldent bother
And on another not like said dont skimp on the last thing you want is a weel fallin off
Where from bio?
I bought 30mm ones from FK a couple of weeks ago and they were £100ish, so maybe a tad less or the same.
EDIT:
http://www.fk-automotive.de/websale7/FK-Wheel-spacer---50-mm-System-B---fit-for.htm?Ctx={ver/7/ver}{st/3eb/st}{cmd/0/cmd}{m/websale/m}{s/fk-automotive/s}{l/English/l}{mi/199-2834/mi}{pi/1510190/pi}{po/1/po}{fc/x/fc}{p1/78816c961af55deab21a6a5526952c51/p1}{md5/7d9f6cdf0165a8850a19b6de2caeed62/md5}
  Slow red one
http://www.fk-automotive.de/websale7/FK-Wheel-spacer---30-mm-System-B---fit-for.htm?Ctx={ver/7/ver}{st/3eb/st}{cmd/0/cmd}{m/websale/m}{s/fk-automotive/s}{l/English/l}{mi/199-2834/mi}{pi/1510189/pi}{po/1/po}{fc/x/fc}{p1/cae3b472bc4b61ec53c32a3aed121e07/p1}{md5/337a558e6d6e5b783896fe858e1ca12a/md5}
Found those but no 25mm
Can someone fill me in on spacers:)
Greeny.
  440i + 182
Does look lower, your blind/lieing/being anal if you think it doesnt, very subtle drop, but its there :)
The system B ones bolt to the hub and then the wheel bolts to them..
30mm per axle (15mm a side) is the smallest you will get in system B spacers IIRC.
Smaller requires system A.
System A use longer bolts through the spacer and the wheel.
Some people think B is safer, which it probably is..
If you get either, make sure their hubcentric as this takes some of the load of the car off the bolts, and onto the hubcentric angle and also makes sure your wheels bolt on straight. If their not hubcentric, don't bother!
I find my spacers made a massive improvement in handling, the car feels totally planted.
I researched a lot online and thought they would make it worse, but boy was I wrong! :)
  Slow red one
Do you mean 30mm per axle or per hub?
I have 30mm per hub but on a Mk2.
erm not sure but like thse I presume
