172 vs 172 Cup
I'm looking to build a track car to compete in SLS next year and I am not sure if buying a 172 Cup is worth the extra money. The car will be getting all interior and heaters stripped out, poly windows, cage etc. It will also be getting coilovers. Am I right in thinking that the only thing left on the car that is different between a 172 Cup and a normal 172 would be the lack of ABS and TC?
Mertin
  Ph1 172&Ph2 172 Cup
Driveshafts are different lengths on the cup are they not, so must be a difference elsewhere for the wider track?
They have more castor due to the balljoint position on the front wishbone but these can be fitted to a non cup car anyway.
Rear has -2deg camber, again can be done on any car with camber shims
Canary172
  172 Cup
Apparently the lower suspension arm interface on the Cup's subframe is further outboard in comparison to a standard 172. As a result the distance from hub to gearbox is greater which requires the driveshafts to be longer.
massiveCoRbyn
  Several
@midge has measured subframes and says that there isn't a difference
  Listerine & Poledo
Get on ebay and you'll probably find a 1/2 dozen other ex-CS Clios that have had most this done already, they pass through here on an almost bi-monthly basis.
You might need to pull out some carpet, or remove some "tasteful" mods for someones ex road/track 'weapon', but better that than destroying an un-modified example
  Ph2 Clio 172
Cup had 5mm thicker rear stub axle bases/mounting flange aswell "apparently"
Is that where it gets the camber from of is that a cup spec rear beam?
I have noticed differences in stub axles but as far as i know thats just another phase difference not cup difference.
